Old 03-21-2014, 10:07 PM   #5
Ziegelsteinfaust
Re: Another frame swap ?
I just finished swapping the body from a C20 to a K20 frame.
The body is the same except for the High hump, but the brackets can be done easily enough. Just take your measure twice, and cut once. The main difference I see is the K series frame is flat on top to help hold the engine mount bracket.
At this point I would consider 52 inch springs, and or another type of front suspension if you ever wanted it. As it would just as easy to do now.
Ziegelsteinfaust is offline   Reply With Quote
