Old 03-20-2014, 12:45 AM   #1
Krwright
Painless harness not so painless
Anyone have a wiring schematic for an 85. I need the interior and engine bay schematic. I'm installing a painless truck harness. The wires are labeled well as stated but I'm uncertain which wire goes on which place on the plugs. Headlights, parking light and all the interior plugs
i do my burn outs in 4wd
Krwright is offline   Reply With Quote
Old 03-20-2014, 08:07 PM   #2
1981Stepside
1981Stepside's Avatar
Re: Painless harness not so painless
The user you're looking for is hatzie. He has most of the factory service manuals scanned all with wiring diagrams
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 03-20-2014, 10:19 PM   #3
84chevyguyid
Did you buy the one that fits in place of the factory fuse block? Looking at going that route with one of mine. Do a search for Hatzie and you should be able to find his wiring diagrams. Subscribing, want to see the finished product.
Mike
84chevyguyid is online now   Reply With Quote
Old 03-21-2014, 02:53 AM   #4
cjlloyd81
cjlloyd81's Avatar
Here's the post y'all were talking about...
http://67-72chevytrucks.com/vboard/s...d.php?t=545416
1966 Dorsett Daytona - 16'6" Fiberglass boat "Suits Us"
1972 Chevrolet P30 Motorhome - "Giddy Up Go"
1986 GMC C3500 High Sierra Custom - "Ruby"
2007 Chevrolet Avalanche - "Faith"
cjlloyd81 is offline   Reply With Quote
Old 03-21-2014, 02:55 AM   #5
cjlloyd81
cjlloyd81's Avatar
Also if you need I just received the Shop Manual and the Service Manual for my '86 P/U. The actual GM ones. Got them off Amazon for like $30 total and they're in GREAT shape! If I can scan anything in for you that hatzie hasn't let me know.
Old 03-21-2014, 03:40 AM   #6
Krwright
I bought #10103 it was supposed to fit in factory hole but it won't. The bulkhead doesn't split like a factory harness. It was also supposed to have the column plugs wired but they weren't. That's where I'm having trouble. You only get one shot with their plugs once you insert the terminal there's no pulling it out. I have pulled my hair out today trying to figure it out with a test light. Thanks for posting the link to the schematic that helps a bunch.
Old 03-21-2014, 08:28 AM   #7
84chevyguyid
The one I am going to use is a 10205. The one you used says universal, maybe thats why it doesnt fit the firewall like the stocker.You can buy removal tools to pull the terminals back out.
Mike
Old 03-21-2014, 09:20 AM   #8
hatzie
Moderator
hatzie's Avatar
Complete '84 & '85 are the ones that are proving difficult to find... I have the 86 Unit manual I just haven't found the time to feed it to the scanner.
X2 on the printed manuals. Get them and use the PDF for the easy search.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-21-2014, 10:58 AM   #9
softballnrd27
Always a work in progress
softballnrd27's Avatar
No wiring is painless.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 03-21-2014, 11:00 AM   #10
Redcap
Wiring is easy, just time consuming.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 03-21-2014, 07:45 PM   #11
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Painless Wiring = Painful Wiring
You have the universal (which I'm sure all of their kits are pretty much universal).
You will need to reuse your old headlight harness as well as the dual tank harness.
What I found to help was to lay our the harnesses side by side and figure out which connectors you will need to reuse / pry off your old harness and put on the Painful harness.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 03-21-2014, 08:02 PM   #12
Krwright
Thanks for the link. It's coming along not to bad but not easy either. I had to cut the million zip ties off and rearrange it to fit. This came with headlight wiring and new headlight sockets but that's the only connectors you get other than under the dash. I got the fuse block mounted and wires roughly ran. I'm making it harder than it should be by testing everything a thousand times before cutting anything. One more day and should have it done.
Old 03-21-2014, 10:34 PM   #13
hatzie
Moderator
hatzie's Avatar
Good wiring takes plenty of time and lots of patience.
There's no such thing as being too careful or taking too much time.
It's easier to do it right the first time than to clean it up afterward.
Old 03-21-2014, 10:44 PM   #14
Krwright
It's a k30. I was looking over the tail section wires and noticed one was labeled "to dome". Would that be for a superburb rear dome light?
Old 03-21-2014, 11:11 PM   #15
hatzie
Moderator
hatzie's Avatar
If this is #10103 this is the install manual from Painless. --> http://www.painlessperformance.com/Manuals/10103.pdf
It looks like there are 2 dome wires in that harness White power and Black ground. The original GM harness uses White Ground and Orange hot in the Dome circuit... just to add to the confusion.
In the above PDF Jump to page 29 paragraphs 10.4.1 & 10.4.1
GM dome & floor "courtesy" lights use a switched ground and unswitched hots described in 10.4.1
I posted a quick and dirty diagram of the dome system to assist some folks a while ago. It doesn't show the "key present" buzzer wire on the driver door jamb switch...http://67-72chevytrucks.com/vboard/s...75&postcount=6
