Old 03-21-2014, 12:33 PM   #1
Pfdchief
55 gmc
i have a 55 gmc 150 that i installed a 79 camaro subframe on. The original radiator support was damaged so i would like to put a aftermarket Chevy support in. will this work? I assume I will have to redo some brakets or is it a bolt in operation? They look completely different in pictures. This is my 1st attempt at building a project and dont want to buy parts that I cant use! Any help??? Thanks
Pfdchief is offline   Reply With Quote
Old 03-21-2014, 04:39 PM   #2
OrrieG
OrrieG's Avatar
Re: 55 gmc
Some say there is a difference in GMC and Chevy radiator supports, but I found one from a 58 GMC and put it in my 59. I stood them up side by side and could not see and difference and so far everything is bolting up fine. Maybe the 55-57 are different????
Old 03-21-2014, 05:54 PM   #3
BBPanel
Re: 55 gmc
I retained the Chevy rad support when I installed the GMC fenders and grill and did not have to do anything special. I did not use the stock radiator because I have a BBC in it so did custom Afco radiator. -Bob
BBPanel is offline   Reply With Quote
Old 03-21-2014, 08:02 PM   #4
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Re: 55 gmc
If your '55 GMC is a 2nd series, I'm sure it would be much easier to use the Chevy support with the Camaro stub, not to mention better radiator mounting too.
Yeah at least '55 and '56 GMC's are different using a center mounted radiator support that required a top hoop which also supported the whole front clip. I'm pretty sure '55 2nd Chevys used a support that mounted from both frame rails with channel shaped frame brackets. The support in my '55 was torched out and the crossmember was gone too along with the missing top hoop. I built a Chevy style support for it. I still have an I-6 so it was built to fit a 1954 Chevy radiator that I had laying around.
Hey, Bob, this is DAC from South Dakota. I have a different name on this forum. I never asked before, but did you put a Camaro stub on your panel? I'm pretty sure what you have done will work great for Pfdchief.
DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 03-21-2014, 08:59 PM   #5
BBPanel
Re: 55 gmc
Originally Posted by 70gmcjimmy View Post
Hey, Bob, this is DAC from South Dakota. I have a different name on this forum. I never asked before, but did you put a Camaro stub on your panel? I'm pretty sure what you have done will work great for Pfdchief. DAC
DAC, no someone put a MII on the oem frame rails before I got it. And mine is a 56 - I assumed Pfdchief was referring to a 55 2nd series. -Bob
Old 03-21-2014, 09:55 PM   #6
Pfdchief
Re: 55 gmc
yes it is a 2nd series. sorry forgot to mention that part
Old 03-21-2014, 10:17 PM   #7
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 55 gmc
I don't believe you!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-22-2014, 01:23 AM   #8
G&R's57GMC
G&R's57GMC's Avatar
Re: 55 gmc
I'm using a Chevy frame under my GMC. The Chevy rad support sits forward of the GMC support thus the hood latch bracket on the GMC hood is a different shape then the Chevy.
So 1 could use a chevy hood or the latch bracket from 1 and then use the Chevy latch and panel, cross piece, Grill and lower panel making the GMC grill a Chevy.
Or fab a latch panel to match the GMC hood bracket and keep the GMC Grill.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 03-22-2014, 01:35 AM   #9
BBPanel
Re: 55 gmc
I'm using the chevy rad support (in 6 cyl position), chevy latch, chevy latch panel, chevy hood and GMC grill.
