03-21-2014, 11:33 PM | #1 |
Tilt steering column
Any one know if any of the new tilt columns are shorter the the old ones ? I have an non tilt right now but would like to get further away from the steering wheel . So I wanted to know if I were to get a title if they are any shorter then the original ones .
1969 C20 CUSTOM "RUMBLEr" |
03-22-2014, 12:20 AM | #2 |
Re: Tilt steering column
Contact Kevsclassic on here. He is the best for columns.
03-22-2014, 09:18 AM | #3 |
2WD Jimmy
^ Yup
03-22-2014, 09:35 AM | #4 |
I believe the truck tilts are the same length as the standard column. Van tilts are slightly longer than both. I would assume any aftermarket columns would be modeled after the original truck columns. You might be able to get a universal tilt that might be shorter though.
You can shorten the steering shaft between the column and the steering box in order to move the column farther forward |
03-22-2014, 11:13 AM | #5 |
I used a van column, just collapse the lower shaft and move the column down closer to the cluster works fine.
