Old 03-21-2014, 10:17 AM   #1
64chevmn
Trac Bar help........
I'm lowering my 1964 c10 5-inches in the rear. I installed the new lowering springs and shock re-locate brackets. Since I have a 1969 12-bolt rear end with the trac bar stud mounted on top of the pumpkin, I ordered the adjustable trac bar for the 1965-69 c10 truck. When I installed the trac bar, it appears that the angle is off a bit and the bracket on the driver's side of the frame where the trac bar fastens to needs to be back about another inch or so? I'm assuming the 1964 C10 and 1965 C10 frames are the same and the location of the trac bar bracket on the driver's side rear frame rail are in the same position?? If i put a load on the suspension, the trac bar will slightly hit the stock differential cover? Is this normal or do I need to relocate the frame bracket?
Dan
64chevmn is offline   Reply With Quote
Old 03-21-2014, 10:46 AM   #2
Clyde65
Clyde65's Avatar
Re: Trac Bar help........
I would get me one from No Limit Engineering, they have the ones that bolt to the frame and then the PS ( I think) trailing arm mount. Allows for a larger pumpkin cover and such.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-21-2014, 04:15 PM   #3
Slow Build
Slow Build's Avatar
The mounting position is a little different between the 64 and 65.
Top pic 64
Bottom pic 65
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-21-2014, 05:04 PM   #4
64chevmn
Thanks for the pictures; but it looks like the bracket on my 64 just needs to be moved back about an inch or so?? It is hard to tell by the pictures, but does the 65 bracket also sit lower than the 64?
Old 03-21-2014, 07:23 PM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
This was the track bar from my 65.. It was cut, shortened and re-welded..
I ended up replacing it with an adjustable one. I didn't have a pic of that available.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-22-2014, 12:19 AM   #6
Captainfab
60-66 Nut
It is mainly the angle of the frame bracket that is different between the '63-'64 and the '65-'72. Yes the '65-'72 bracket is slightly further rearward too.
Old 03-22-2014, 01:20 PM   #7
glos55
glos55's Avatar
I notice LMC list three different part numbers for the Arms. (60-62) (63-64) (65-66)
LIFE IS SHORT HAVE FUN
glos55 is offline   Reply With Quote
