Re: Camper special shortened and converted to 4x4
Okay questions.... I'm going to pull the inner fenders and maybe the outter fenders then install front 4x4 gear... I'm using rear hangers from a 79, I know they aren't the same as 67-72... Should work though, my question is about the steering box, I have a 4x4 steering box but in other threads I've read that they don't match up bolt hole wise... What do I need to do? Also I'm going to put the trans in, got an auto trans and 203 case out of a 79 gmc, does the trans crossmember go in the same holes as a 2wd? Is it that easy? Or do I need to drill? And where should I drill... Also unsure about motor mounts... Do I need to just find 67-72 4x4 mounts? Or are there other options? Thanks for any help!
