Old 03-20-2014, 08:33 AM   #1
BigBlockBurris
BigBlockBurris's Avatar
One Ton Pic Request (Rear Frame) PICS ADDED!!!
Does anybody have a pic of a one ton truck (133" wheelbase) with no bed on it? I specifically need a pic of the frame from behind the cab to the end of the frame. I have '71 ton, and I need to verify number and location of crossmembers. I think I may be missing a few.
Thanks in advance.
BBB
BigBlockBurris is offline   Reply With Quote
Old 03-20-2014, 11:26 PM   #2
swamp rat
swamp rat's Avatar
Re: One Ton Pic Request (Rear Frame)
Maybe give this guy a PM???
http://67-72chevytrucks.com/vboard/s...9&postcount=29
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-21-2014, 02:06 AM   #3
crazy longhorn
Fabricate till you "puke"
Thanks in advance.
BBB
After the trans crossmember, is one right @ the rear of the cab (center bearing support on the D-shaft),then @ the front of the leaf hangers, & the last one tween the rear leaf hangers....Longhorn, on a 133" base
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-21-2014, 06:46 AM   #4
SS Tim
SS Tim's Avatar
Picture enough or do you need a drawing?
Send me your email if you need it (fullsize).
SS Tim is offline   Reply With Quote
Old 03-21-2014, 12:30 PM   #5
BigBlockBurris
Thank you both for the reply.
The pic Tim put is exactly what I was hoping for.
I am missing the rear most crossmember.
Thanks again!
BBB
Old 03-21-2014, 02:38 PM   #6
SS Tim
SS Tim's Avatar
One more then.
Old 03-22-2014, 01:08 PM   #7
BigBlockBurris
Tim,
Thank you again. That rear cross member is exactly the one I am missing and that I need.
Got one?
Thanks!
Alex
Old 03-23-2014, 05:43 PM   #8
BigBlockBurris
What I need!!! BAD!!!!
Old 03-23-2014, 06:11 PM   #9
SS Tim
SS Tim's Avatar
Guess someone thought that the receiver hitch was enough.
As far as locating one. Dude, I live in California.
However Jenn and Jeremiah King may very well have one but shipping could be expensive to NC. www.kingstrucks.com
They are members here on the board jeremiah king
http://67-72chevytrucks.com/vboard/member.php?u=41714
Might be best to find a local cut off frame section and someone to huck fasten the crossmember into your truck.
Old 03-23-2014, 07:23 PM   #10
BigBlockBurris
Tim-I know shipping would kill the deal, I was just picking.
I have looked local with no luck.
Thanks again for your pics, and help. It appears that whoever removed mine, did a neat job, thank goodness. I hope to find another to put back.
I agree, the hitch is not enough.
BBB
Old 03-23-2014, 07:33 PM   #11
uncle
Wouldn't 3/4 be the same on leaf spring truck?
uncle is offline   Reply With Quote
Old 03-23-2014, 07:34 PM   #12
NC67Chev
NC67Chev's Avatar
BBB
Have you checked with Whites in Germanton? If not, it might be worth a call.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 03-23-2014, 08:02 PM   #13
SS Tim
SS Tim's Avatar
Good point!
Looked it up in the parts manual and the service part only fits 30s and 133"wb 20s (Longhorns).
There are different numbers for 10-20 applications.
Good news is the part seems to backfit to 1955.
Old 03-23-2014, 08:52 PM   #14
BarryB
BarryB's Avatar
Let me look, tomorrow, I have a 1 ton I am parting out, the frame rails had some rot so I am cutting it up.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 03-23-2014, 11:52 PM   #15
kwmech
What you need is a frame with the inside measurement of about 4.25'' and a center to center on the back most rivet of 31''. I just measured my longhorn x-member
Old 03-24-2014, 06:57 PM   #16
BarryB
BarryB's Avatar
Here are the couple pics of mine, Sorry but I've got a fuel tank sitting there. fit nicely inside the frame rails so it doesn't roll.
Two rules in life.
