#3276 |
Re: What Did You Do With Your Truck Today ?
Got it into the garage under it's own power (!) and got rid of 10 or so rivets to get rid of some un-needed frame.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
#3277 |
Seems like that is how it goes. The things we worry about the most end up being easy. I think it is because we do it so many times in our head it seems familar. I was that way about the door hinge pins. Put it off for ever and ended up taking less than half an hour for the pair that needed fixed.
#3278 |
took the 55 to a glass place to get a new gasket installed,,,,, you guessed it,, they broke the windshield
#3279 |
Filled the radiator and tank with antifreeze and ran the gas line up the frame rail. will get the bend put on it tomorrow and connect to the filter/regulator. then I can measure for the braided hose to the fuel rail. Maybe startup next week!
tbrown's 56 Cameo Build |
#3280 |
It is alive. Put in the new starter, primed the carb, added 2.5 more gallons to the tank and it fired on the first crank. Would not idle, looks like the used carb that was "just taken off a running car" is shot. But it moved under its own power, more detail in the build thread.
#3281 |
I put on some new shorter gas shocks on the rear. Wow! What a difference. Also put in a new distributor. Still working out the bugs on the timing and carb tuning.
Just because you can, doesn't necessarily mean you should. 1959 3100 stepside 355 + T5 |
#3282 |
Got firewall finished and drivers floor in.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#3283 | |
http://s1156.photobucket.com/user/Or...ipped.mp4.html
#3284 |
Got first rubber on the asphalt............yee haww.......(forward & reverse).
The 355 is a torque monster! R&P power steering works excellent..........well..........in the driveway. Gambled on the 350 TH with new TC and fluids, seems to be good. Front discs-rear drums good...........well again........in the driveway. |
#3285 | |
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#3286 |
Switched the gas gauge lines and all is well, but cost me some blood, tight fit up there. Also noticed that one turn signal lamp is dimmly glowing with the key off, so get to start the search for a reason. suspect original 1959 light switch....
#3287 |
Mounted front bumper. Tucked it in 3".
#3288 |
I had my son out in the shop learning how to handle a spray gun on the weekend. We got the bed in black epoxy on Satuday.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#3289 |
![]() Join Date: Dec 2012
took the burb to painter to do his magic
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
#3290 |
duh, can't be the light switch, brake and turn are not switched...search continues..
#3291 |
Bent and installed fuel line. Mounted drivers side mirror. Looks like they are going to work fine!
#3292 |
#3293 |
yesterday I replaced fuel lines all the way up to the tank, I'll have to finish cleaning the tank and install that, then bend up the remainder of the fuel line. all on the GMC.
72' K10 LWB (Ole' orange) 59' ![]() 01' Ram 1500 (great white) 98' Honda civic (cirvics) |
#3294 |
Today... I sat and looked longingly at photos of it and wished it was here so I could work on it.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
#3295 |
Yesterday I build the pipe from Driver's exhaust manifold to where I'll hang the muffler & found a place to put the first exhaust hanger.
Today I ordered some glass packs for it.
#3296 |
![]() Join Date: Mar 2007
Pulled all of the glass out of the 53 suburban.
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#3297 |
Started on sandblasting the frame on my 57 3200, word of advice make sure your shop door is closed all the way. Had media all over inside my shop, learned from that one lol.
#3298 |
Put the bed back on after spraying the epoxy primer
#3299 |
dubie
truck looks great !!! very ''sinister'' |
#3300 |
pulled the cab and steering off and started cleaning the frame.
1st Series 55 Chevy Pickup 235 4 speed |
