Old 03-10-2014, 07:48 PM   #1
roxxx
Whats the softest Riding 4 inch lift ?
I have a 4 inch all spring lift in my 1992 Dodge from Skyjacker with a set of Bilsteins Its okay but the Chevy is going to be much lighter and is a short bed so choppy
I emailed and Called Deaver but just wondering what other options i may have.
Thank you
roxxx is offline   Reply With Quote
Old 03-11-2014, 07:23 AM   #2
ryanroo
ryanroo's Avatar
Re: Whats the softest Riding 4 inch lift ?
That is a pretty hard question to answer. in order to know, you would have had to install kits from several manufacturers on the same truck with the same tires and wheels.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-11-2014, 07:29 AM   #3
Shackle-flip rear and longer springs
Old 03-11-2014, 11:45 AM   #4
b454rat
52s up front and 64s out back...
Old 03-11-2014, 11:48 AM   #5
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
These will be your softest, flexiest options. But for off the shelf, direct bolt on springs, it's hard to beat the ride of Tuff Country springs.
Skyjacker, Superlift, and Rough Country are all pretty well known to ride pretty stiff.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 03-11-2014, 07:03 PM   #6
roxxx
shackle flip and 52/62 ok were would I start looking for this application more so what springs and were would I buy them from ?
Thank you
Old 03-11-2014, 11:53 PM   #7
52s are rear pickup/Blazer/Jimmy springs up to '88 truck & '91 Blazer/Jimmy. 62s are rear springs off an '88 or newer truck/Suburban/Tahoe/Yukon. www.offroaddesign.com for the shackle flip
Old 03-12-2014, 04:36 AM   #8
roxxx
Thank you
Old 03-12-2014, 07:17 AM   #9
ryanroo
ryanroo's Avatar
so far as i know, they are 64" not 62" you can also find 60" rear springs from a suburban.
72 K20 12v build
Old 03-12-2014, 08:37 AM   #10
GCncsuHD
GCncsuHD's Avatar
88-98 are 63" 99-current are 64".
Also www.diy4x.com for another shackle flip option and the B52 brackets up front.
ΜΟΛΩΝ ΛΑΒΕ
Old 03-13-2014, 08:57 AM   #11
manimal
manimal's Avatar
You can also have custom springs made to YOUR specs by Alcan or Deaver.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 03-23-2014, 09:12 PM   #12
rocket20
I also am thinking about 52s up front is anyone running 38s and 52s up front if so what lift 52 are you running and did you fan your own brackets or purchase the kit from diy4x? I have stock 52s but I don't think it will clear 38s or even a wider set of 35s
rocket20 is offline   Reply With Quote
Old 03-24-2014, 02:07 PM   #13
b454rat
Depending on the condition of the springs, they normally get around 4-4 1/2" of lift. I ran 38.5" boggers with 4", but cut the crap out of the fenders...
Also don't need a kit to run 52s, move the forward spring mounts forward, it all bolts in....
Old 03-24-2014, 08:35 PM   #14
rocket20
But doesn't that locate the tire forward or back in the fender well ?
Old 03-25-2014, 08:30 AM   #15
GCncsuHD
GCncsuHD's Avatar
Absolutely, but you still have to address the rear shackle mount location for the optimal ride and flexibility. This is even more important on the 67-72 than the 73-87 due to the even shorter factory front springs. Going with the B52s just allows more adjustment to fine tune your axle location and shackle angle. And the 67-72 B52 kit includes the shackle mount, optional for the 73-87 trucks.
Yes. 67-72 springs are 44" 73-87 springs are 47", this mod puts 52" up front. All springs have centered locating pins. Going forward ~3-4" would keep the axle located in the same place, but generally, if you intend to use your truck offroad you will want to go even farther forward for more tire clearance at the firewall/rear of fender. With the longer flexier springs, as your suspension compresses, your axle will move rearward towards the firewall farther than the stock springs. Also it gives your more front driveshaft length for a better angle, less wear on u-joints and less binding.
ΜΟΛΩΝ ΛΑΒΕ
