Old 03-25-2014, 11:40 AM   #1
OrrieG
OrrieG's Avatar
Re: Lurker OrrieG Progress Pics
Thanks guys I appreciate the feedback. I just pulled the hazard fuse, I think it may just be an issue with some feedback because none of the turnsignal, tail or brake lights are hooked up. If not then it might be something in the switch internals, if that is the case then looks like I will be going old school without the hazard feature I am not going to go back into the column or replace it unless it affects the turn signals. For all I know a bug could have crawled up in there for the winter and is causing the problem. Once had that happen with an old house thermostat, earwig got trapped between the contacts and when we went to turn on the heat for the first time in the fall he fried and furnace would not start. Little clean up and point file and I was good to go.
