Spring on RH kick panel duct with factory AC
My 1972 GMC has factory AC and there is supposed to be a small spring going from the kick panel door to?? Does anyone have a picture of how the small spring goes from the door to??
![]() Thanks for any help GR |
Re: Spring on RH kick panel duct with factory AC
After a bit more under dash looking I found where it anchors. Thanks to anyone who was looking into this for me.
GR |
Old member
Should be just a peice screwed to the flapper door.Lower picture.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
