Old 12-31-2003, 01:50 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Grill fix idea's
Anybody got any idea's on how to fix this outside of getting a new grill ? Also I would like to keep the grill aluminum color and not paint it.. Any idea's would be great.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-31-2003, 03:24 AM   #2
PR454SS
PR454SS's Avatar
You can repair the aluminum and then buff it out.
I picked up some repair rods at a truck show once it worked real well, even polishes. It's called Aluminum repair rod and its from Pro Products inc. 1-800-822-6935
Hope that helps
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 12-31-2003, 12:17 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Those aluminum rods are pretty slick and only require a small propane torch.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
