Old 03-14-2014, 09:59 PM   #26
Andy4639
Old member
Andy4639's Avatar
Re: Major Setback
Well I picked up the truck today. I was surprised this morning after talking to Bruce. He had Carolina Driveline do a one peice drive shaft for the truck at his expense not mine. $490.00 and it looks great!
The transmission he said was fine other than the rear tail section bushing and seal. They replaced it and he flushed the trans out good 2 times he said. Changed filters each time and said it was good to go. He gave me a 30 day garuntee with it. I would like to have had it rebuilt but with the 30 days I'm Ok with it. We will see how it does. Driving to the beach next week so that should be a good test for it. 5hrs each way running 70-80 all the way.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-15-2014, 05:53 AM   #27
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Re: Major Setback
Its refreshing to see the right thing done. Kudos to the shops involved! Enjoy the ride to the beach!
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 03-15-2014, 07:34 AM   #28
Andy4639
Old member
Andy4639's Avatar
Talking Re: Major Setback
Well I hope everything is good inside the transmission. I will tell it by next week I hope if not. The driveshaft looks to be 100% in everyway which is good. When I drove it home yesterday I went the long way home to hit the 4 lanes and gotter up to 70-80 MPH and held it for a mile are so. I had a sound that I never had before so I was worried. I went by my buddies shop and had him drive it by himself so he could see if anything seemed wrong. He came back and said it drove great and he didn't feel anything. So I'm good with it. He told me the one peice may have a differant sound to it compared to what I had before with the 2 peice.He told me to take my hearing aids out when driving it! Ha... Most of the time I do anyway!
Old 03-15-2014, 12:56 PM   #29
akdg87
akdg87's Avatar
Re: Major Setback
Andy: what's the diameter on the new driveshaft?
I'm looking at having one built next week
DG
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 03-15-2014, 06:09 PM   #30
Andy4639
Old member
Andy4639's Avatar
DG
I went out and measured it. Looks as though it's 4". I need to get a calipor on it to make sure though. It narrows down at the yoke and at the rear end to maybe 3". I'll get some more pictures.
I drove over to the local truck meeting today in Greenville SC that I help organize so I haven't had a lot of time. I've been down loading pictures since I got home. We had 33-35 trucks show up today!
Old 03-20-2014, 09:22 PM   #31
Andy4639
Old member
Andy4639's Avatar
Well I drove it to Myrtle Beach last night 289 miles and it ran fine. Everything was good. The drive shaft seems to be hallow and it is making the noise at highway speeds. I wrapped duct tape around the center of the shaft before I left and it made it a lot quiter up until about 80 MPH. I will call the shop back next week and see when they can look at it. It needs to be cut open and have insulation installed welded back and rebalanced. That is what I'm being told anyway.
Old 03-20-2014, 09:38 PM   #32
Ozzy2013
Ozzy2013's Avatar
Re: Major Setback
Originally Posted by jjzepplin View Post
Wait a minute. You took this in and they first-cut the shaft too short-Second, did not balance it,-third , removed it and balanced it and then reinstalled the then too short shaft without making it the right length. And then only when you brought it to their attention they are going to fix it. Makes you wonder if they really rebuilt your trans in three days and how well it was done, if it was actually done. HMMM
I am with Byran H on this one.
For your sake, I hope they really fix it.
I was thinking the exact same thing not only did they screw up once but they did it twice!The so called mechanic would be fired if he worked for me!
Ozzy2013 is offline   Reply With Quote
Old 03-20-2014, 10:11 PM   #33
Houston Ben
Houston Ben's Avatar
Re: Major Setback
Andy,
Sorry to hear about the problem but glad it got corrected and not at your expense. I can emigine how pissed you were, I had a different WTF than yours but still not a fun experience.
Houston Ben is offline   Reply With Quote
Old 03-20-2014, 10:49 PM   #34
Andy4639
Old member
Andy4639's Avatar
Cool Re: Major Setback
Yes I wasn't happy at all about it but he made it right. Now I have to get the drive line shop to fix the howling sound it makes when running the interstate speed's!
Old 03-20-2014, 10:59 PM   #35
Houston Ben
Re: Major Setback
I did my first "long" drive last week and it ran like a champ, crused @ 80 for 3 hours with no problems, feels good right?!
Old 03-20-2014, 11:28 PM   #36
68c10airstream
68c10airstream's Avatar
Re: Major Setback
Hi Andy, reading this series of posts related to your driveshaft woes i noted on post #26 what looks like the riveted carrier bearing support brace that was attached to the crossmember was torched off and the flames discolored the crossmember and and discolored areas in the same region on the new driveshaft??? If so, is the driveshaft warped from being torched at??? The discoloration has a light blue hue to it on my screen. Hope all goes well.
68c10airstream is offline   Reply With Quote
Old 03-21-2014, 07:09 AM   #37
truckdude239
truckdude239's Avatar
Re: Major Setback
Man thst driveshaft is really close to that cross member
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-21-2014, 09:53 PM   #38
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Major Setback
68c10airstream, you may be on to something there. I hadn't really payed that any attention.
If your talking about this picture it's the angle of the picture.
Old 03-22-2014, 03:15 AM   #39
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Major Setback
Is there a good amount of room on either side? Even with the angle of the picture, if the 1piece shaft is a larger diameter you have less tolerance on either side. Its not necessarily a problem, just something to keep your eyes on as you use it a bit.
If your out on the road and hit some woopdy-woops or choppy roads that would bounce and try to off-center a suspension, take a look at the shaft after you come back...just to make sure there is no sign of scoring on near the pass-through.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-23-2014, 06:44 PM   #40
Andy4639
Old member
Andy4639's Avatar
Wink Re: Major Setback
Good idea. I will check it out this week. I just got home. Truck seems to be fine but will check on it. Not driving it for the next few days until I get all the show stuff squared away.
Old 03-23-2014, 07:13 PM   #41
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Major Setback
all good man, just don't want you to get on the road and find out on the way to Myrtle!
Old 03-24-2014, 11:45 AM   #42
Andy4639
Old member
Andy4639's Avatar
The truck sitting at the show. I took the picture of the truck in front of the Power Tour bus last June in Chattanooga Tenn before I left out for Charlotte that morning. Had it blown up and went to Hobby Lobby and bought a cheap frame and table top easel for it. Less than $20.00.
Here is the link for the car show.
http://s1233.photobucket.com/user/an...24467353832517
Old 03-27-2014, 07:03 AM   #43
Andy4639
Old member
Andy4639's Avatar
Well this past wekend at the car show I meet some cool people. One of them was a friend of Charlies the guy who did the tune on my truck at Hawks. I gave him my number and he said he would have him call me. Well Wednesday night he called, I was surprised but very glad he did. We talked for a hour and next week we are going to do a drive tune on it. I'm going to pick him up and he is going to see what he can do with it. I told him I was going on the power tour in June and he said we may can get 1 are 2 more MPG out of it. That's not a bunch but every bit helps. He is going to look at everything again and make sure that it's right.
Still got to call the drive shaft place though.
Old 03-27-2014, 09:58 AM   #44
oldman3
oldman3's Avatar
Re: Major Setback
Good news on the tuner, truck looks great, nice pics of the show...Jim
oldman3 is offline   Reply With Quote
Old 03-27-2014, 12:06 PM   #45
Andy4639
Old member
Andy4639's Avatar
Thanks I took over 500 pictures.
