03-26-2014, 08:50 AM | #1 |
Temp Gauge
Hey guys, I drained all the fluid out of my radiator because it was real dirty and brownish and the gasket was bad on the thermostat so I decided to replace the thermostat and put new fluid in the radiator. When I am driving the truck runs approx. 180-190 degrees but from time to time (mainly when I am coming to a stop) the temp jumps up to 260 degrees. I push in the clutch and rev up the engine and it jumps back down to normal temperature. What could be causing this?
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
03-26-2014, 04:35 PM | #2 |
Re: Temp Gauge
Are you running a fan shroud?
Sounds like at rest your not getting the air to pull thru the radiator.
03-26-2014, 04:40 PM | #3 |
Re: Temp Gauge
It's all stock. Are you talking about the aftermarket fans that mount to the radiator?
03-26-2014, 06:40 PM | #4 |
Re: Temp Gauge
No I meant the factory one that fits behind the radiator and wraps around the fan
03-26-2014, 06:49 PM | #5 |
Re: Temp Gauge
Oh ok, yeah my truck has that.
03-26-2014, 07:07 PM | #6 |
Re: Temp Gauge
Fan clutch failed? Or maybe an air bubble?
Throwing out suggestions.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
03-26-2014, 11:37 PM | #7 |
Re: Temp Gauge
Bad water pump? Maybe the impelled is trashed and only flows enough when at a higher RPM or moving. Also check your thermostat. It may be sticking?
03-27-2014, 08:55 AM | #8 |
Re: Temp Gauge
Someone suggested that I start by loosening up my radiator cap and driving for a short time. If that didn't fix it then have Autozone check my cap and or replace it. Then look into changing out my water pump.
03-27-2014, 09:56 AM | #9 |
Re: Temp Gauge
I would double check that the temp gauge is reading correctly first.
How many blades does your fan have? IIRC some have 5 and other have 7. How quickly does the temp rise at idle? |
03-27-2014, 11:21 AM | #10 |
Re: Temp Gauge
Several years ago I bought a radiator cap with a built in temp gauge in it. That way I can double check my temp and compare to my gauge. It has come in very handy.
03-27-2014, 11:35 AM | #11 | |
Re: Temp Gauge
Sounds like a very good idea.
03-27-2014, 12:31 PM | #12 |
78K & 79C Jimmys
Re: Temp Gauge
you mention real dirty and brownish...
any chance it's fluid was mixed green and red? could it have a stop leak in there?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-27-2014, 12:46 PM | #13 |
Re: Temp Gauge
The water looked rusty. The truck sat for 10 months prior to me buying it without ever being started.
03-27-2014, 03:20 PM | #14 | |
78K & 79C Jimmys
Re: Temp Gauge
anything but a nice bright green I'd reflush it
03-27-2014, 04:02 PM | #15 |
Re: Temp Gauge
Yeah I drained it and filled it back up with half and half
