Old 03-29-2014, 06:35 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Disc brake upgrade: Hoses and hardlines
I like to use the entire hard lines and hoses from 73-87 trucks. Master cylinder too.
Its a near drop in job. Get everything from the firewall out to the banjo bolts as one assembly from the junkyard. You can install it all in an hour using nothing more than a drill and a 5/16 bit along with the standard line wrenches for tightening the fittings.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-30-2014, 05:18 PM   #2
WiggyHD
Firewall out to include the booster and prop valve? That would make it a ton cheaper! The truck that the dust covers out for the front brakes still has everything. Just one phone call to my friend the yard owner and all is good!
THANKS!
Mark
Retired Air Force/Disabled Vet
1969 Chevy C-10, On the way to greatness!
WiggyHD is offline   Reply With Quote
