Closed Thread
Old 03-28-2014, 11:43 PM   #3301
Nev68
Nev68's Avatar
Re: What Did You Do With Your Truck Today ?
Started fitting the Vintage air AC kit (what could possibly go wrong?)
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline
Old 03-29-2014, 11:38 PM   #3302
tbrown5079
Finished the gas line. Had all the fluids in so tried to start. Fired right up and runs real smooth , but no throttle response. Need to hook up the OBD11 port. Seems like no commmunication between the PCM and the throttle body.
tbrown's 56 Cameo Build
tbrown5079 is offline
Old 03-30-2014, 08:34 PM   #3303
OrrieG
OrrieG's Avatar
wiper fluid lines, tighted up fan belts, reviewed list it got much smaller this winter (new on right).
OrrieG is offline
Old 03-31-2014, 03:28 PM   #3304
Russell Ashley
Russell Ashley's Avatar
Man you are more organized than I am. Do you use a spreadsheet, like Excel, to make your to-do lists? How are your headings labeled? I don't have a list like that, I usually just know in my mind what I want to do next and go with it. Or get sidetracked and do something else, LOL.
One thing I have done with this truck is kept a spread sheet with a very accurate listing of parts, date purchased, where I got them, and how much I've spent. I've never done that with a project before.
Russell Ashley is offline
Old 03-31-2014, 04:28 PM   #3305
OrrieG
OrrieG's Avatar
I too have a cost spreadsheet. Both are in excel, headings are Work, Task and Buy. Work is broken down into clean, fabricate, sand, paint and install. Early on it was easy to stay on track without it, but then I found myself going in circles because I had forgotten to buy something, or backtracking. Also needed a sense of what I could do that did not require funds, or like last year over the winter that was not temperature sensitive. I also find that with so much else going on with my business, wifes stuff, taking care of my Dad's affairs, ect. once I get something down on paper my mind can focus on other stuff.
OrrieG is offline
Old 03-31-2014, 04:37 PM   #3306
capnduane
capnduane's Avatar
Got real tired of looking at the ugly greasy sheet of plywood in the bed of my pickup. But didn't want to spend mucho bucks at this time for a fancy bed redo (with walnut burl wood and polished chrome strips). Ya Right! Maybe someday when I win the Lotto! The original wood and metal is still there, but 60 years old, whats left of it! So, I did what any old carpenter would do under my circumstances, I sided over it. A sheet of T111 exterior siding, a few deck screws, and a quart of "Varathane stain+poly" Doesn't look to bad from 20ft, and If it gets beat up (which it will, cause I use my truck) I can touch it up with more Varathane. The Varathane is water based and goes on nice.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder"
capnduane is offline
Old 03-31-2014, 04:50 PM   #3307
rollenhard
rollenhard's Avatar
Nice capnduane! Looks brand new
Just Cruzin Through Life
rollenhard is offline
Old 04-01-2014, 11:24 AM   #3308
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Flushed and re-bleed the brakes. And since I had the wheels off I washed and waxed the back sides. Its an illness I know!!
ChuckDriver is offline
Old 04-01-2014, 12:32 PM   #3309
SCHRUMGMC
SCHRUMGMC's Avatar
Just bought a new Air Filter to replace the old one, that was filthy
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 04-01-2014, 06:59 PM   #3310
4DSEVEN
4DSEVEN's Avatar
Mounted the box and rear fenders. Waiting for the exhaust tip for the other side and will bolt them up. Still have a few things to do but ready for spring.
4DSEVEN is offline
Old 04-01-2014, 10:01 PM   #3311
Dan in Pasadena
Dan in Pasadena's Avatar
Well, if it's an illness I'm afflicted too!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline
Old 04-02-2014, 09:10 AM   #3312
nvrdone
Leaving in a bit & driving the truck for the first time to work. Its 12 miles so shouldn't be a problem. Wish me luck.
nvrdone is offline
Old 04-02-2014, 06:05 PM   #3313
Ozzy2013
Ozzy2013's Avatar
Wow looks really good!
Ozzy2013 is offline
Old 04-03-2014, 10:35 PM   #3314
lgoodso1
Installed new fuel tank in my 57, worked on sandblasting frame parts and steering links. Getting closer to start on getting a rolling frame
lgoodso1 is offline
Old 04-05-2014, 10:36 AM   #3315
brikar
brikar's Avatar
recovered my steering wheel to match the interior
brikar is offline
Old 04-05-2014, 01:25 PM   #3316
Russell Ashley
Sweet! Nice job.
Old 04-05-2014, 01:30 PM   #3317
Rednek13x
Rednek13x's Avatar
just did a $1,200 order off of summit for my engine
Rednek13x is offline
Old 04-05-2014, 02:32 PM   #3318
oldman3
oldman3's Avatar
Very nice work, looks great...Jim
oldman3 is offline
Old 04-05-2014, 03:10 PM   #3319
Johnny49
Separated the hubs from the front drums, which was a lot easier than I thought it was going to be. Unfortunately, it was also a lot easier to ruin the hub with the small sledgehammer I was using to drive the studs out, as you can see with the hub in the foreground. Don't know what the heck I was thinking. Didn't even notice it until afterwards. Maybe the wife is right when she calls me "Bam-Bam."
In addition to that little example of amateur genius, you'll notice that the studs are still sticking through the backing ring on the left. That's because they had been welded to the ring. No idea why. I was also reminded what happened when I originally tried to have all the drums turned. Not enough material left to turn on the right front, and one of the rears was warped (according to the shop guy). Which is why I figured all four should be replaced. And because I wasn't being careful with the sledgehammer, now I need the hubs too. I know we'll be able to find them somewhere, just a matter of making it fit within the budget...
Johnny49 is offline
Old 04-05-2014, 06:56 PM   #3320
Nev68
Nev68's Avatar
Great job. Can we see it installed?
Nev
Nev68 is offline
Old 04-05-2014, 07:23 PM   #3321
tbrown5079
Cut, bent and installed the last piece of brakeline. Will fill and bleed next week. If I get my throttle issue solved I could drive around the block.
Old 04-05-2014, 08:42 PM   #3322
apache200
apache200's Avatar
Bought some new chrome pieces for the truck today
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline
Old 04-05-2014, 09:31 PM   #3323
OrrieG
OrrieG's Avatar
Redoing the e-brake cable run, geometry was not right and it was not working. I hate welding on my nice shiney frame....
OrrieG is offline
Old 04-05-2014, 09:51 PM   #3324
mr48chev
mr48chev's Avatar
In addition to that little example of amateur genius, you'll noticeurn loose that the studs are still sticking through the backing ring on the left. That's because they had been welded to the ring. No idea why. Which is why I figured all four should be replaced. And because I wasn't being careful with the sledgehammer, now I need the hubs too. I know we'll be able to find them somewhere, just a matter of making it fit within the budget...
There is a good chance that someone who is swapping to 5 lug hubs or someone going to an independent has good drums and hubs that they will turn loose of reasonably and are close enough so you don't have to pay shipping but just drive a few miles. Tell the wife that you want to take her for a ride but have a stop to make along the way.
My ongoing truck projects:
mr48chev is offline
Old 04-05-2014, 10:29 PM   #3325
brikar
brikar's Avatar
here you go
brikar is offline
Closed Thread
