Manual to Power steering, whats needed?
I would like to convert my 67' C-10 from manual to power steering and have a few questions. First, will a power steering box from a 69-76 chevy work? If not, what year will work? When looking at the front end rebuild kits from ECE I noticed a reduced price for the power steering kit, what components are different? Thanks to all for the help.
On the eighth day, he made trucks and saw they were good. |
You need a pump with pulley, belt, steering box with pitman arm and the 2 hoses. You also may have to cut a notch out of your front bumper bracket to fit the box properly, it's common practice.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Thanks Dubie, will the pitman arm off a 1971 C-10 work with the steering box from the 73-76 and will this box line up with the existing hole in the frame
I think so. I know a fellow who put power steering on a 68 GMC with a 250 inline 6 and a 4 speed truck tranny. He took all of the parts off of a 73 pickup and had no problems that I am aware of.
1968 Chevy - 292 with a powerglide |
Thanks guys!
to add you may need to change your Main pulleys (fan/crank) to get grooves right and a lined
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ ![]() ![]() |
Sleep-Deprived
I'm putting power steering on my c/10 right now too, along with
"a few other" improvements. Doing it on a inline 6, though (just assumed yours was an 8). Also to add, what I've been told is the pump from a 73-78 will fit (non-metric line fittings). Also was told it's a faster turn ratio than the ps gear from 67-72's. I got one from a 77 and hope to be fitting it to the frame this weekend. Was told to get the pitman arm from the 73-78. Different spline pattern (i'm guessing)? There might be some issues when lowering, that unfortunately, I don't know about. Hope this helps.
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
Not Dusti,just Bob
I think the frame on a 67 is not the same as 68-72,were the gear box bolts onto the frame there is an indentation for the gear box,on a 67 there is not an indentation.
Bob
72 cheyenne super 1/2ton 89 camaro |
the pitman arms are different for manual and power steering and also the rag joints (connect steering column to steering box)
![]() Join Date: Feb 2000
Here's a link I came across today about adding power steering when I was looking for metric conversion parts. http://www.classicperform.com/tech_a...steer-this.htm
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
