03-31-2014, 12:41 AM | #1 |
Auto Meter Oil and Water temp gauge
New build, new gauges, new Ron Francis wiring. We have good power to the gauge feed into these 2 gauges, but, at the sending units on the manifold, we have a very weak light on our test light. We have good grounds, actually all the gauges are grounded in the same place. Fuel gauge is working, volt gauge working, but, water and oil pressure gauges are not working. Shouldn't we have 12 volts at the oil and water sending units also?? Help...
03-31-2014, 01:35 AM | #2 | ||
Re: Auto Meter Oil and Water temp gauge
The sending units ground via their threaded connections into the engine. So for proper operation, you need to have a good ground connection from the engine to the GND terminal on the back of the Autometer gauge. |
