Re: ***omg...94 Amp Alt. On Your Trucks***
[QUOTE=Sport/truck
Rage-n Rat- was yours a CS 130? s/t[/QUOTE] i don't remember ---- 84 camaro ---94 amp the kit from frank is a direct plug in kit.. no extra wiring, no cutting, nothing. |
NOT REALLY BANNED!
![]() Join Date: Jul 2004
A 100amp 1wire int reg alt from autozoo or summit is about $100 and a bit less hassle.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
#3 | |
Sierra Grande Club
http://www.madelectrical.com/electri...hreewire.shtml s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
i'm buying a kit off of hi as soon as I am ready to hook it all up...$25 shipped he said
Sierra Grande Club
Can anyone else help with this wiring mystery?
s/t
Sierra Grande Club
can you post a link?
thanks s/t
notice This Picture Is Incorrect
ANOTHER MEMBER MADE HIS OWN JUMPER AND WE FOUND OUT THIS IS NOT THE CORRECT JUMPER PATTERN IN THIS PICTURE I CHECKED THE CUSTOM MADE JUMPER PACKAGE FROM FRANK WITH A METER AND BELOW IS THE CORRECT JUMPER PATTERN #1 the Two Outside Wires Are Supposed To Be Jumpered Together #2 the Two Inside Wires Are Jumpered Together Last edited by rage'nrat638; 07-12-2007 at 06:54 AM. |
BY THE WAY I INSTALLED THIS ALT 12-31-2003, 08:53 PM
FOUR YEARS LATER STILL THE BEST IMPROVEMENT I HAVE DONE TO MY TRUCK...... OTHER THAN PAINTING IT ![]() |
On the jumpers in the 4 pin connector, when you jump the red and white wires together, where do the white wire lead from the connector. I have seen the conversion without jumping the two insides and terminating the white wire. I am planning on doing the switch this weekend and wanted to make sure I was doing it correctly.
70 GMC 1500 2wd lwb 00 Chevy 2500 |
Wrenchin & Sandin!!!
I did this also because of this thread. Excellent Mod
![]() Thanks Mark!
Randy ![]() Shorewood, IL. My Favorite eBay Searches My Driver Restore Thread 1971 C10 Longbed 2005 Silverado Shortbed 2005 FXDWG Last edited by Draggn66; 04-03-2007 at 11:51 PM. |
I'M TRUCK CRAZY!
I am going to have to look into this when I put project Low Dough back together.
![]() Join Date: Aug 2005
Why jumper the two inside connections?
I'm a little slow....
Somebody post a link to Frank's user profile so I can find out about one of these conversion kits...... |
#15 |
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#16 |
Mine is a 140 amp model...and chrome!
Alex 1971 Lil' Red 350 SBC 700R4 |
#17 |
well i used a meter on the connector jumper supplyed in franks kit and the two inners are connected together.
where they go and what they do i have no clue. i just wanted to make sure you did not connect them like that picture showed that is not correct..if i could delete it i would. any more questions please just ask or p.m. me i will be happy to help. your pal mark |
#18 |
This is a great thread! Thank you guys, this is exactly what I need, I was wondering if any of you guys know if I could take my Chrome alternator in to have it rebuilt to put out 140 amps? I hate to replace it with a cast looking one, or have to spend alot more money on a new Chrome one.
#19 |
i am sure you can. check out the yellow pages in your area.
chances are theres a rebuilder in your area. i had one rebuilt before. worked great.. ![]() |
#20 |
Is the 84 Camaro alternator a 3 wire setup ?
I have a 77 GMC and it has a 3 wire alternator (1 screw terminal + 2 prong flat plug) so I'm wondering if it will be a direct plug in and bolt up. |
