Old 04-01-2014, 05:35 PM   #1
grs
Need pictures of washer hoses
I need pics of the hoses going into the cowl area. My truck never had washers. Not sure were to drill the holes, or what size hole. I have the nozzle parts, and a universal washer pump.
grs is offline   Reply With Quote
Old 04-01-2014, 07:46 PM   #2
pimpston65
pimpston65's Avatar
Re: Need pictures of washer hoses
i can find some pics, but im doing the same to my 65 i know there should be dimples in the sheet metal just to the right of the heater box for the drivers side hose and just to the left of the master cylinder the same dimple for the drivers side hose. as far as the hose whatever size fits the nozzle is the size. make sure you get the clips i just did a pick and grabbed all 3 left the oem washer bottle i forgot it
pimpston65 is offline   Reply With Quote
Old 04-01-2014, 07:50 PM   #3
pimpston65
pimpston65's Avatar
pics of the clips for the hose, plus u need the firewall grommet with the 3 holes for the washer pump the come from the bottle to the pump and out the pump to the nozzles
Old 04-01-2014, 07:52 PM   #4
pimpston65
pimpston65's Avatar
pics of the hole location
Old 04-01-2014, 07:53 PM   #5
pimpston65
pimpston65's Avatar
other side
Old 04-01-2014, 07:57 PM   #6
pimpston65
pimpston65's Avatar
pic just shows location, if you want oem its one hose off the bottle to pump. the two hoses off pump to each nozzle the pick shows a T-piece this is not correct
Old 04-01-2014, 08:34 PM   #7
grs
Thanks that helps a lot. Now I need to find some clips.
Old 04-01-2014, 10:02 PM   #8
pimpston65
pimpston65's Avatar
any style will work. i just saw them on my most recent pick and grabbed em inline tube sells all kinds of clips and stuff there close to me so i can drive to em
Old 04-01-2014, 10:06 PM   #9
pdxhall
pdxhall's Avatar
Here's one more pic of the firewall with the washer hoses.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-01-2014, 10:13 PM   #10
grs
Old 04-02-2014, 01:00 PM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
Mine isn't factory, but the nozzles are. They are circled in the cowl vent, and the hoses were run through grommets in new holes drilled in the cowl and firewall flange. I have my universal washer pump mounted under my washer bottle:
I think the bottle is from a 1983 C10. I bought it at the local Chevy dealer for about $5.
Here's an overall shot showing the washer bottle, and a close up of the factory nozzle on the driver side:
Obviously I hadn't tied up the wiring or the washer hose yet when this photo was taken.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-02-2014, 07:01 PM   #12
grs
Looks good. My pump is under the washer bottle too. I drilled the holes for the hoses that go to the nozzles. They have grommets. Do you have a grommet for the hose from the tank to the fire wall? I think the metal is thick. It may not take a grommet.
Old 04-02-2014, 07:16 PM   #13
BADAZ chevy guy
BADAZ chevy guy's Avatar
Don't know what this has to do with Chevy's, but here ya go.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-08-2014, 08:33 PM   #14
grs
Hot and cold washer hoses. Nice.
Old 04-09-2014, 12:31 AM   #15
Captainfab
60-66 Nut
That's because I have an electric pump mounted beside the reservior
pic just shows location, if you want oem its one hose off the bottle to pump.the two hoses off pump to each nozzle the pick shows a T-piece this is not correct
Old 04-09-2014, 03:00 AM   #16
markeb01
Senior Enthusiast
markeb01's Avatar
Yes I have 3 grommets. Two for the hoses going to the nozzles, and another where the bottle hose goes through the firewall lip.
Old 04-09-2014, 08:34 AM   #17
pimpston65
pimpston65's Avatar
yeah i figured something was different as only one hose is going to the passenger side and not all three. just giving info to the member of what i know and have seen of unmodified trucks
Old 04-09-2014, 03:16 PM   #18
grs
I thought I posted how I ran the hoses. I finally got the washers working.
Old 04-09-2014, 04:51 PM   #19
markeb01
Senior Enthusiast
markeb01's Avatar
That's exactly how mine are routed, but yours show up much better with the color contrast.
Old 04-09-2014, 06:14 PM   #20
grs
I got the idea from you. Thanks
Old 04-10-2014, 12:27 PM   #21
MisterC
MisterC's Avatar
Damn that came out clean. Bookmarked for another "to do"!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
