So a purchased and moved the fuel tank to the rear of the bed. And I just saw a video advising that I need to cut the beds cross member because it will hit the tank and not sit on the chassis??? Is this correct info?
I am using the Blazer tank conversion kit from LMC... Nothing is ever easy, eh?? ![]()
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
![]() Join Date: Nov 2004
Re: Moving gas tank to the rear..
Yes, you need to cut the rear brace.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Or grind off the rivets and reposition it????
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
That won't do much because by the time you move it far enough there's a brace pretty close to either end of the tank... the brace in question is pretty much over the middle of the tank. Lots of people have cut them. I took mine out (stepside - bed never gets used).
the boat guy
I took mine out. It was about as easy as working on old trucks gets.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#6 | |
![]() Join Date: Mar 2014
Still Learning
I don't know about the kit from LMC but the one I bought from Kenny's trucks required cutting one of the braces. THIS is how I did mine. (toward the bottom of the page). It only took a few hours.....
I cut mine and then put in a 1/4 inch flat bar for support.
Junior Member
![]() Join Date: Mar 2007
easy would be leaving the stock tank in place....
frontstreetcycle on Instagram |
Thanks for the info guys. Will be cutting and grinding this weekend.
