Old 04-02-2014, 07:58 AM   #1
ol_skool_chevy
ol_skool_chevy's Avatar
aftermarket steering columns
Any aftermarket steering columns, Speedway or Flaming River Ididit I bought a new big window cab and completely going thru it....what have you used?....how long is it?..photos??
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 04-02-2014, 10:27 AM   #2
Robert Haas
Re: aftermarket steering columns
The polished aluminum Ididit was a simple bolt in. I ordered the unit without the gear indicator and went with the billet LCD in dash unit. Name:  reflection 3 7-10-2008 6-12-08 PM.jpg
The tilt feature is handy.
Robert Haas is offline   Reply With Quote
Old 04-02-2014, 12:42 PM   #3
doobiebro
doobiebro's Avatar
I have installed two columns (1 on Ebay hot rod GM universal 32") and another from CPP..both under $199.00 shipped and very happy with it. I also bought the rag joint, OD universal joint and collapsable steering shaft as a kit from CPP.... here are sum pics..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 04-02-2014, 04:40 PM   #4
jb9281
jb9281's Avatar
HI doobiebro!! I am install a CPP column. How did you clamp/bolt it in? Any pictures?
jb9281 is offline   Reply With Quote
Old 04-02-2014, 05:46 PM   #5
doobiebro
doobiebro's Avatar
(slight fab work) all I did was install a piece of 5/8 heater hose smashed between the lower part of the dash and steering column (for tighter fit) and used the original park brake lever mounting assy... drill 2 holes on steering column tube and install 2 short threaded inserts (but not necessary) to bolt to park brake lever mounting assy...you will use the original lower mounting ring clamp on the fire wall and replace the foam between the cover and firewall.. I dont believe your truck will have the lower mounting ring clamp but here is a stock pick of the park brake mounting assy with the 2 holes. PM me if you need any help..
Old 04-02-2014, 08:29 PM   #6
gimmy 64
I bought one from pol--performance online for about $200 and it was an ididit column. bought the adapter for the wiring and it was americanautowire. bought the shaft and joint from cpp and I think the whole thing was about 200-250. been a couple of years.when I installed it I put the column as far forward as I could. gained maybe a couple of inches
gimmy 64 is offline   Reply With Quote
Old 04-03-2014, 01:06 AM   #7
Garagisti
Garagisti's Avatar
This is next on my list. I need to do this.
1965 Chevrolet C10
2016 Mercedes S550
1992 Mercedes 300TE
Garagisti is offline   Reply With Quote
Old 04-03-2014, 11:07 AM   #8
racecougar
racecougar's Avatar
Something to watch out for: http://lvvta.org.nz/documents/infosh...ng_Columns.pdf
Originally posted in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=581452
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 04-03-2014, 12:24 PM   #9
PGSigns
PGSigns's Avatar
That was some good reading.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-03-2014, 02:26 PM   #10
TJ's Chevy
TJ's Chevy's Avatar
Good info here guys! Giving me ideas!
