Old 04-02-2014, 12:27 AM   #1
87Skier
87Skier's Avatar
Time for a new fuel tank?
I've got a fuel tank that has been sitting with gas in it for some time and has a lot of gunk built up to the line where gas was sitting. It doesn't "appear" to be leaking but after cleaning who knows.
Should I even attempt to clean it or just plan on getting a new tank?
Here's a picture of the inside of the tank.
Thanks, Travis.
87Skier is offline   Reply With Quote
Old 04-02-2014, 10:03 AM   #2
briank
Re: Time for a new fuel tank?
You could try ,hard to clean really good because of the baffle. Try a radiator shop to do it then seal it with a tank kit.
briank is offline   Reply With Quote
Old 04-03-2014, 12:07 AM   #3
Jdubs71
Jdubs71's Avatar
You can get a new tank with mounting hardware and sending unit for around $200.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 04-03-2014, 01:02 AM   #4
rwhite692
The poly tanks are available also for about $200 with a new pickup/sending unit.
rwhite692 is offline   Reply With Quote
Old 04-03-2014, 09:14 PM   #5
87Skier
87Skier's Avatar
Yep, I saw that several places sell the kit for around $200 not including shipping. I asked a radiator shop about it and he recommended going with a new one.
Next question...
Poly or steel? I've heard several opinions about which is better.
Old 04-03-2014, 09:31 PM   #6
notsolo
notsolo's Avatar
Save the goose neck off your old tank, might come in handy. New 1's don't come with it.
notsolo is offline   Reply With Quote
Old 04-03-2014, 09:32 PM   #7
87Skier
87Skier's Avatar
Thanks for the reminder. I've seen that most of the new tanks come with a shorter generic neck.
