Old 04-06-2014, 01:31 AM   #1
cleansquare
No more pawpaw truck
Been thinking of jacking up front end of my 3/4 ton. There wasn't much info on doing this so I decided not to.
Then last week a friend said "Man when you passed me on the highway at 85 your truck sounded awesome! You gonna level it out?"
So I was like dang now I'm thinking about it again. More research showed me the moog 6454 coil. Its the 3/4 ton HD spring and 1 ton LD spring. I ordered them from oriellys for $114 and installed them today.
I gained 2 solid inches up front. I can't see any difference in the angle of the tires, I may have it aligned after I do some balljoint work. The ride is nice, not stiff like people warned me it would be. I'm enjoying it. I also had both front rotors turned and also rear drums. Found out one drum was severely warped which wss what was causing my hopping and vibrating at braking. Swapped it out for a new one and smooth as silk. What do yall think?
cleansquare is offline   Reply With Quote
Old 04-06-2014, 01:40 AM   #2
Re: No more pawpaw truck
Looks good
Old 04-06-2014, 08:14 AM   #3
oldmann1967
Looks like it is going uphill now. Can't really level these trucks and have them look right. The distance between the tire and wheelwell gets out of order.
oldmann1967 is offline   Reply With Quote
Old 04-06-2014, 08:43 AM   #4
71swb4x4
71swb4x4's Avatar
It does look a little nose high now. Is the rear leaf or coil?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-06-2014, 09:07 AM   #5
Wrecked1982
Wrecked1982's Avatar
i like it too
Wrecked1982 is offline   Reply With Quote
Old 04-06-2014, 09:23 AM   #6
cleansquare
The rear is leafs. Camper special. I have a 1" block kot but that would give me rake again. I think it looks great. Look at the bed and cab, its level. The wheelwells look good to me too
Old 04-06-2014, 10:04 AM   #7
79Betty
79Betty's Avatar
Looks stout, strong, BADASS!
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 04-06-2014, 10:19 AM   #8
monte0185
monte0185's Avatar
Lookin Good!!
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-06-2014, 10:47 AM   #9
meatwagon83
meatwagon83's Avatar
i likey!!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 04-06-2014, 12:11 PM   #10
K5owner
You could do a ORD zero rate in the rear if you feel it is riding too high in the front. I think it looks perfect.
K5owner is offline   Reply With Quote
Old 04-06-2014, 09:48 PM   #11
cadillac_al
The rear is higher because it is empty. Every truck looks like that when empty. When it is loaded then it will be too low. It will really be nose high if you have to haul something. Good looking truck though.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 04-06-2014, 09:53 PM   #12
rudey737
I think it looks good. Nice truck!
Azulita - 84 Chevy Scottsdale Longbed 305/350
rudey737 is offline   Reply With Quote
Old 04-06-2014, 10:00 PM   #13
Matador
I'm not a fan of lifting or lowering trucks, but...
I think it turned out great! The stance looks great! You may have to add air bags to the back to keep it from squatting too much if you haul heavy loads or tow with it, though.
Looks great!
Matador is offline   Reply With Quote
Old 04-06-2014, 11:05 PM   #14
cleansquare
Thanks captain obvious
Old 04-06-2014, 11:14 PM   #15
cleansquare
Looks great!
Thanks. 5 or 6 times a year I tow a 30' pontoon. Other than that I drive it 80 miles a day the rest of the year unloaded.
I think it'll be ok.
Old 04-07-2014, 08:56 AM   #16
Slammed84
Slammed84's Avatar
+1 !!
I might be crazy but if I'm correct, the front fender wheel opening is cut a little higher than the rear.
That is the reason why his truck is dead level if you look at the bedrail vs. the ground, but it still looks like the front end sits higher now.
I feel these trucks look a little better with a slight rake because of this.
I know this isn't a great picture but its the only one I have from when my truck was still together, its from a couple years ago. Its dropped with a flip kit in the rear w/ 2.5'' spindles and we cut one coil out of the stock spring.
we put it all back together to see how it would sit w/out cuttin the spring and it was way too high in the front.
Its hard to tell but it has a slight rake to it but the fender gaps looks pretty equal, which is proof that the fender openings are cut a little higher on the front fenders.
Slammed84 is offline   Reply With Quote
Old 04-07-2014, 09:05 AM   #17
Slammed84
Slammed84's Avatar
HEY!!! IM NOT CRAZY!!!
First two pics are the rear.
Second two are the front fender.
Measured from the center of the opening to the body line.
ALOT bigger difference than I expected... almost 2'' !!
Old 04-07-2014, 09:30 AM   #18
Looks healthy! Any concern with rear end droop when loaded/towing can be remedied with Air Lift auxiliary bags. Solves cosmetic concerns while "adding" to the virtues of the truck as a real truck. Adjust air accordingly while adding true extra load capacity. Wheel openings am most anything are obviously taller to allow for suspension cycling while steering.
Old 04-07-2014, 10:47 AM   #19
cleansquare
Yes guy's, the front wheel opening are taller. Yes the truck is designed to have a rake when empty. No I do not like that look. Yes I like the look it has now. Lol.
I like the idea of air bags. Had them on a 91 cummins dually. Might look into them.
Old 04-07-2014, 01:03 PM   #20
nekkidhillbilly
Looks great!
i agree it looks good. i like a very mild drop or lift.
nekkidhillbilly is offline   Reply With Quote
Old 04-07-2014, 01:05 PM   #21
cleansquare
I'm off today and its a beautiful day so ill go grab theboat and get a pic that eill tell us if I need airbags or not.
Old 04-07-2014, 05:56 PM   #22
cleansquare
Yep, gonna need bags! The boat isnt too too bad but the rv is way low.
Anyone know a good kit?
Old 04-07-2014, 10:58 PM   #23
y5mgisi
Second Chance Program
y5mgisi's Avatar
Looks great!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 04-08-2014, 07:44 AM   #24
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Looks great!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-08-2014, 10:15 AM   #25
Desert1957
Desert1957's Avatar
Last year you wanted to lower it? What changed your mind?????
http://67-72chevytrucks.com/vboard/s...d.php?t=594356
http://67-72chevytrucks.com/vboard/s...d.php?t=594245
Desert
Desert1957 is offline   Reply With Quote
