#3326 |
Re: What Did You Do With Your Truck Today ?
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
#3327 |
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#3328 |
Got the cab off yesterday . Need to finish up some welding , then need to blast the cab an all the rest of body parts ... Build the chassis .
#3329 |
My chevy 51...... http://67-72chevytrucks.com/vboard/s...d.php?t=541148 www.knutselracing.nl |
#3330 |
Yesterday went about 106 miles round trip to The Koskonog Goat sale. Sold our billy goat and some unwanted roosters. Bought a Regestered Nubian Milk goat. She is pregnant and due to kid in a week or two. A couple of guys tried to buy my Zombie truck. One offered $500?
#3331 |
#3332 |
Wow, that could have been me and my buddies in the late 60's. Only thing missing was the girls we were trying to impress!
#3333 |
Oh, me too. Those were the days......
#3334 |
Today I went and filled the bed with firewood& and then loaded up a LB stepside I had at my other place. I plan on replacing the fleet side with the step side. Pictures of the bed and the goat I hauled yesterday.
#3335 |
#3336 |
![]() ![]() Carburetor is in serious need of a trash can and the head lights don't work. Steering feels good and the breaks work.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
#3337 |
Pulled the pickup out of the shop today and started working on my inner door panel restoration.
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original |
#3338 |
Pulled the Q-Jet off and put it back together. PO tried to rebuild it.
#3339 |
![]() Join Date: Aug 2011
pulled out the radiator bracket to begin restoring it, not sure I want to put the hours into it now. It looks to have been repaired in the past and not sure if its safe to repair again. What do you guys think?
See pix
Pat 1949 unmolested Indy Farm Deluxe AD 1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544 |
#3340 |
sandblasted the frame on my 57 3200, then primed it. First step on getting the chassis back together, tomorrow will paint the frame
#3341 |
welded in some patch panels.
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
#3342 |
Figured out I got one wire to the trailer harness wrong, but ran two spare circuits to back so easy fix. 12v power would have been on a circuit only live when the engine is running....
#3343 |
![]() Join Date: Dec 2012
Nothing much
Found out the Air blower works in my '59 but only works on low, the resistor will need replacing eventually. Tried figuring out why the Right Turn signal and Brake light isn't working.. Assuming its Switch related because of changing fuses out etc
1971 GMC Sierra 1959 GMC 100 |
#3344 |
R&R the hood and Left front fender so I could adjust the drivers door.
#3345 |
Secured another handful of lines / wires, trying to keep things from melting / rubbing thru / catching fire. Drove it around the block just to see how it went.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
#3346 |
Took my 15 year old grandson for his first ride in the truck yesterday. He's still smiling.
#3347 |
installed my cab molding
#3348 | |
Watch this video and spend $25 on an inexpensive multimeter, will save a LOT of time chasing electrical problems. Then you can see if its the socket, wiring or turn signal switch that is the problem. Also get about 16 feet of 16 ga wire, cut in two and solder aligator clips (one black,one red) on one end of each piece. Wire nut them together you have a jumper, undo them and you have extensions for the multimeter for testing resistance in long circuits. https://www.youtube.com/watch?v=bF3OyQ3HwfU
#3349 |
old truck man
nice goat !!! |
#3350 |
sanford & daughter
very very nice cab molding on your truck !!! |
