Clutch Pedal question
Looking for a clutch pedal assembly for my 72 c10 and was wondering what years was this part the same? (i.e. clutch pedals from 67-72 will only work on 67-72 etc). Anyone know the actual part number for the pedal assembly?
Re: Clutch Pedal question
I don't know the number but any from a C or K truck from 67-72 would work in there. It shouldn't be that hard of an item to find. take a look in the for sale section and see what is in there. Any member on here [like me ] that has or had more than one build going and had a couple of parts trucks might have a pedal set laying around if not still in the truck cabs. Good luck in your part search, if you don't find one in a reasonable amount of time send me a PM and I'll check with a guy that has a [secret stash] of stuff but I only contact him in desperate times.
2WD Jimmy
![]() Join Date: Mar 2005
Call Wes at: http://www.classicheartbeat.com/
Thanks for the replies guys. I have already emailed Wes and no luck on a clutch pedal or a high hump transmission cover!
![]() Join Date: Oct 2010
I think I still have one or two in the storage building. You want me to look for you tomorrow?
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Yeah man that would be awesome! Are you referring to having a clutch pedal or high hump transmission tunnel? Either way I need both if you have them. With the clutch pedal I was hoping to get the pedal itself, return spring, rubber return bumper pad, and the circlip that holds the pedal on. Thanks!
Did you find this yet? I have a full clutch assembly.
