Re: 62 inline 6 speed ideas
If you currently have a 230/250/292 and you're planning on adding a small block later, the only trans I'd look into would be a '94-'97 LT1 F-body T56. All the components needed to adapt them to a inline six would work to adapt to a small block, so you'd only be buying parts once. You'd want no lower (numerically) than 4.10 gears (4.56 if you have taller tires) to make use of sixth gear. With a 29" tall tire and 4.56 gears, you'd be doing 2000 rpm at 76 mph. They're rated at 450 lb/ft so you won't tear it up either.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
