Old 04-07-2014, 05:44 PM   #1
adricar1
removal of rear cab window
Can some one please tell me how to remove the rear window from the cab. There is a stainless steel trim around it and i do not want to damage it removing the glass, the window has an opening sliding window fitted. i have found a water leak from the window which is wetting the rear cab corners and causing them to rust.
GMC K1500 1971 350 cu in th350 4wd
Bondo Bob c 10 1971 stepside th 350
c10 1970 350 cu in manual air con stepside.
adricar1 is offline   Reply With Quote
Old 04-07-2014, 08:50 PM   #2
MidLifer
MidLifer's Avatar
Re: removal of rear cab window
I typed "rear window removal" into the Google search box at the top of the page and there were tons of threads, including this one:
http://67-72chevytrucks.com/vboard/s...d.php?t=536815
MidLifer is offline   Reply With Quote
Old 04-07-2014, 11:32 PM   #3
tcoop68
tcoop68
tcoop68's Avatar
Razor blade just cut the lip inside the cab and it will come right out then take gasket off the window. Same with the front
tcoop68 is offline   Reply With Quote
Old 04-08-2014, 01:53 AM   #4
adricar1
cheers guys, i do not have a replacement rear seal so i need to get it out in one piece if possible. They are not available here so i will need to order one in next time i have a delivery from America
