Old 04-09-2014, 07:28 PM   #1
earl84
PS adapter fitting
I need to find an adapter from a '92 metric O-ring PS pump to a '79 AN Flare PS gearbox, and am having a tough time. I am not at home to measure them right now so I don't know which end of the PS hoses are the large end, but the '92 hose end fittings are 16mm male and 18mm male, and the '79 hose end fittings are 3/8" male and 7/16" male. Can anyone help me out with this?
I only have the '92 PS pump and cannot change out the fittings on the back of the pump, so i need an adapter, and I really just don't feel like going to a junkyard. I'd love to order from Summit because I have some other stuff to order, but I am hoping for an assist from you guys, because I have looked and just can't seem to locate. HEEEEELP!!
earl84 is offline   Reply With Quote
Old 04-09-2014, 07:39 PM   #2
luvbowties
luvbowties's Avatar
Lightbulb Re: PS adapter fitting
Check with your farm-implement dealers. They prolly have facilities to make any hydraulic hose you need--if all else fails, surely they can take 2 hoses & make 1 that fits on both ends.
sam
luvbowties is offline   Reply With Quote
Old 04-09-2014, 08:03 PM   #3
murphy98
murphy98's Avatar
Try these guys, they should have the adapter fittings you need.
http://www.purechoicemotorsports.com...=cat/cat99.htm
murphy98 is offline   Reply With Quote
Old 04-09-2014, 09:05 PM   #4
tincan1966
tincan1966's Avatar
why can't you just change out the fitting in the back of the pump? This exact thing was covered in a different thread just last week. All you need is the fitting from a 79 and earlier pump, 5 minutes to switch it out and problem solved/
Just did this same switch in a '94 pump so should be the same.
tincan1966 is offline   Reply With Quote
Old 04-10-2014, 08:55 AM   #5
earl84
tincan, I addressed that in my post. I don't have the pump from the '79 and just don't have the time now to go find it at a junkyard, as I am not at home right now. Wanna get back home and have a fitting waiting for me to put in place and move on to the next thing. Maybe I should just see if I can find that fitting from the back of a pump to purchase instead of an adapter fitting. Less joints is better.
Old 04-10-2014, 08:56 AM   #6
earl84
BTW, thanks everyone for your replies, always so helpful.
Old 04-10-2014, 09:04 AM   #7
tincan1966
tincan1966's Avatar
OK sorry I guess I misunderstood "cannot change out fitting" for "I don't want to change fitting"
I was just offering the quickest/easiest solution.. My point was if you changed that fitting then stock parts store hoses from a '79 would be a direct fit and not have to have custom hoses made. that's all.
but to answer your question, try searching Aeroquip/Earl's for fittings. most likely tho, there's are going to be Female oring to the pump and a male AN for the hose- so you'd have to have a hose made with a female AN fitting on one end a male flare on the other. or more adapters, and possible leaks.
Old 04-10-2014, 01:14 PM   #8
61K10
61K10's Avatar
here you go
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-10-2014, 07:22 PM   #9
earl84
Called both Purechoice Motorsports and CPP today, and left messages. Neither called me back. Frustrating. I thank you all again for your replies. I'll keep trying.
