Rear end Swap ?
Can anyone ID this rear, and can I put it under a 71 K -10 ? Guy said it is out of a 86 1/2 ton, also comes with front D44 thanks, is it a 10 bolt ? Should I wait for a 12 bolt ? Truck will not be off road !
71 C-20 07 Magnum RT AWD |
Re: Rear end Swap ?
It's a 8.5" ten bolt, just as strong as a 12 bolt and way cheaper to Posi and gear swap
Re: Rear end Swap ?
Thanks for the information ! I am glad, it already has posi in it ! Perches and shock mounts are different then 12 bolt ?
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Rear end Swap ?
Perches should be the same. One shock mount will be correct the other won't. The71 mounts both pointed towards the front. Later years they're staggered.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
![]() Join Date: Sep 2009
Re: Rear end Swap ?
Perches on 1/2 ton 86 k models are 42.25" center to center. Pre 73 k models are 40.25"
Re: Rear end Swap ?
Can you change a 71 K10 frame to later style shock set up ? Frame is bare right now so anything I can do to improve it, now is the time. I picked up both front and rear axels from a low mileage 86 K10, front axel was almost never in gaged ! $300.00 for both.....
Re: Rear end Swap ?
Another thing to consider, does the gear ratio of this 10 bolt match the ratio of your front axle? Or are you swapping out both? Still safe to check that the new set is a match if you're swapping both. Seen a few trucks with mismatched ratios. Further, what transmission are you running? Visible in pic is what appears to be a 208 TC, most commonly mated to 700r4, those transmissions work best with 3:73 ratios, 3:42 and 3:08 gears cause it to take longer to shift into overdrive.
#8 | |
Re: Rear end Swap ?
Re: Rear end Swap ?
Ha ha you posted while I was typing. Since you will have to move the leaf spring perches on the 86 axle, I would move the shock mounts on the axle too, rather than changing frame mounts.
Re: Rear end Swap ?
Both of my original axels are junk so I am swapping both from the 86, 373 with posi in back. After pricing new parts to rebuild the old 12 bolt I feel I did OK ? Going to use the original 205 TC out of the 71. The one in photo is out of the guys 86 I got the axels from. Thanks for the input .....
#11 | ||
Re: Rear end Swap ?
67-87 two wheel drive half ton leaf spring are all 42.25 67-72 k-10, 20, and 30 are 40.25 73-87 k-10 are 42.25 73-87 k-20, 30 are 40.25 as are the two wheel drive 30's. The only one I'm not sure ( memory issues ) are the 67-87 two wheel drive 20's (3/4 ton) Last edited by starvinartis; 04-09-2014 at 01:04 PM. Reason: additional info |
#12 | |
![]() Quote:
Last edited by starvinartis; 04-09-2014 at 01:01 PM. Reason: additional info provided |
Re: Rear end Swap ?
Whats a common rear end everyone is using when goin from a 6 lug to a 5 lug? And a disc with posi? Ive looked and looked and cant seem to find any answers.....can someone help
Re: Rear end Swap ?
When changing 63-70 to 5 lug I try to use 71-72 stuff. Just my preference. 70 rear diffs with the big brake drums will accept 71-72 five lug axles.There are plenty of after-market sites that sell disc brake conversion kits for any of these axles.
#15 |
Re: Rear end Swap ?
Im lookin for a stout rear end for the fact im building upa 5.3 with a turbo set up Nd gonna be bagged and body dropped on 24s
#16 |
Re: Rear end Swap ?
The driveshaft from the transfer case to rear axel has a yoke that slides back and forth, will this make up for shaft length difference ?
#17 |
I don't think it will because at curb weight that slip yoke needs to be in the center of it's travel. Extending it to compensate will cause it to bottom out as suspension travels while driving. I just did a walk-thru of my yard to take a measurement but I have no 10 bolts. Plenty of 12's tho. Seems like the 10's wear out/break more than the 12's. We can't keep the 10's they go so quick. And they have those cheap a** guv-lock posi's or a tensile "s" shaped piece of steel that simply puts pressure on the spider gears. Give me a clutch type 12 bolt posi anytime over those. But if its a daily driver never off road and you don't lift it or go with oversize tires it should last a while. And you thought this would be easy and cheap? Just kidding.
#18 | |
Re: Rear end Swap ?
Sorry my phone puts in words it deems fit regardless of what I type. Repunched instead of relaunched Last edited by starvinartis; 04-09-2014 at 04:32 PM. Reason: additional info |
#19 | |
Re: Rear end Swap ?
#20 |
Re: Rear end Swap ?
I think I will start with the front axel first ? Thanks guys ? How can a 10 be so weak ? GM thought it was good enough for a truck ?
