Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-28-2014, 02:28 PM   #1
MikeS.
MikeS.'s Avatar
How hard is it
To remove the dash on my 63? Maaco is concerned it'll be a major PITA. They are also concerned they might find major issues once it's removed. I doubt that will be the case though.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 03-28-2014, 11:38 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: How hard is it
I thought they were welded along the windshield area. I didn't think they unbolt out, so it's likely going to be a major issue getting it out and it will need to be welded back in. Could be wrong as I don't know the 60-63 cabs as well as the 64-66 cabs.
Anyone have an answer?
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-29-2014, 12:12 AM   #3
Captainfab
60-66 Nut
Re: How hard is it
Are you talking about the entire dash, or just the instrument cluster? The entire dash is bolted at the ends as well as some spot welds there, and then it is spot welded along the entire length of the bottom of the windshield. Yes is is a bit of a PITA. I see absolutely no reason to remove the dash.
I thought Maaco just did a quick block sand, shoot some color and call it good.
Captainfab is online now   Reply With Quote
Old 03-29-2014, 12:23 AM   #4
BADAZ chevy guy
BADAZ chevy guy's Avatar
Re: How hard is it
If you're talking about removing the entire dash (Metal and all) here's a video set that walks you through the entire process. He's working on a 1977 C10, but the principle should be the same. https://www.youtube.com/watch?v=HfEuljIG_nc
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-09-2014, 09:54 PM   #5
MikeS.
MikeS.'s Avatar
Re: How hard is it
Captain, they can do the scuff and shoot but they can do much more as well.
On mine they are going to take the entire outside to bare metal, a panel or 2 at a time. Rough primer/sealer it and onto the next panels. Will take them awhile to get it all done. Once it's stripped down then Bondo and repair as needed. Finish prime, sand and then paint, 2 tone on mine, elec. blue on the body nickel on top and pillars.
The inside is in much better shape, scuff and paint.
Past Master
Old 04-10-2014, 08:14 PM   #6
RockTonka
RockTonka's Avatar
Re: How hard is it
If you don't think there are any major problems in that area, why would you/they consider removing the dash?? I've attached some pics of my boys project (truck, but dash is same) to show the number of spot welds along the dash/windshield intersection and what's behind/under there...as Cap has mentioned, it would be (is) a major PITA and doesn't really allow unique access to much
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
