04-10-2014, 08:55 PM | #26 | |
the boat guy
Re: Questions for fellas with ls swaps
My factory tach hooked right up to my pcm after it was reprogrammed to send 8cyl signal instead of a 4 cyl signal. I don't know anything about a tach module.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
04-10-2014, 09:58 PM | #27 |
All the info you need can be found to do the harness yourself can be found here
http://lt1swap.com/ I did the harness myself and have little in it but my time, its a very fun sub project that anyone can do if they can follow directions. Brendan will also reprogram your PCM (remove VATS) for $75 on Gen III engines and $150 on Gen IV. Look that site over good, all you need to know is there. Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
04-10-2014, 10:01 PM | #28 |
Tac is throttle actuation module the brain between pedal and throttle body.
04-11-2014, 09:31 AM | #29 | |
-Richard
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
