Old 04-11-2014, 08:50 AM   #1
coldgin
can i do this?
just went through the engine in my 69 3/4 ton gmc...wandered when putting the engine back in the truck can I have the distributor in the engine or should I leave it out or leave just the cap off?i pulled it with distributor out but used a ratchet strap hooked to the water pump to keep it level and going to use it again to install the engine and thinking back I thought I could have left the distributor in the engine when I pulled it...
coldgin is offline   Reply With Quote
Old 04-11-2014, 08:56 AM   #2
cdowns
cdowns's Avatar
Re: can i do this?
yes i pull engines all the time with distributor in
Old 04-11-2014, 09:33 AM   #3
rkn463
rkn463's Avatar
Re: can i do this?
I'd definitely remove the cap and rotor as the break easily if hit. The distributor itself being metal can take light abuse without sustaining any damage.
- Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
