Old 04-10-2014, 09:33 PM   #1
PHAT TONY
PHAT TONY's Avatar
New truck O/D question
I picked up a 1971 Chev 1/2ton for prolly 30 cents on the dollar, owner knows NOTHING of the truck he's had for 17-18 years AND had restored(repainted with MANY new parts) while overseas in '04/5. "3 speed auto?" I says; "yup, original trans rebuilt" he says, on the ride home I count the tranny hit 5 times every time....o/d with lock up convertor, 700R4 pan apon home inspection, but the convertor seams to lock up between 3&4(3 hard shifts, 1 soft, 1 last hard)...and NO wires from the trans. I've got a 700 in my Blazer with a B&M thingamubob for conv lock up, nothing in the 71-I've looked everwhere!! The electric plug on the side has no connector even! Is there a way to lock it up internaly without power? Older non-electric trans? I don't know and am looking for something here....
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 04-11-2014, 08:55 AM   #2
67 chevelle
67 chevelle's Avatar
Re: New truck O/D question
The electric plug on the side is what locks the trany , if its unhooked your trany is not locking , should shift 3 times either way 1-2 , 2-3 , 3-4 , they make converters that are non-locking , that have no clutch in them , mostly used in retrofits , like what you have , your first gear must be really low , especially if you have 373 or 411 gears , most of the vehicles 700r4s were put in had 308s
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-11-2014, 10:10 AM   #3
engineer_gregh
engineer_gregh's Avatar
I was told there is a kit available that will automatically lock up the converter once you're in 3rd gear. Its internal to the 700r. Maybe a transmission guy can chime in and tell what kit that is.
engineer_gregh is offline   Reply With Quote
Old 04-11-2014, 10:17 AM   #4
Hart_Rod
Hart_Rod's Avatar
Originally Posted by engineer_gregh View Post
i was told there is a kit available that will automatically lock up the converter once you're in 3rd gear. Its internal to the 700r. Maybe a transmission guy can chime in and tell what kit that is.
+1
Hart_Rod is offline   Reply With Quote
Old 04-11-2014, 11:21 AM   #5
ERASER5
ERASER5's Avatar
Yes there is a kit. You might have gotten better responce if this were in the Engine & Drivetrain section. Clineburger(sp) hangs out there and is a professional transmission guy.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-11-2014, 12:02 PM   #6
67 chevelle
Every kit I have ever seen requires 12 volts to run
Old 04-11-2014, 09:02 PM   #7
PHAT TONY
PHAT TONY's Avatar
My bad; the tranny hits 4 times not 5, I will post in the eng/drive section, thanks.
1972 K10 4X4-Sold
Old 04-12-2014, 09:44 PM   #8
Slammed66
Needs a Big Block
Slammed66's Avatar
Sweeeeeeeeeeeet truck!!!
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
