Old 04-13-2014, 02:26 AM   #1
775stepside
Gauge cluster question
Picked up a cluster from a guy who said it came off of a 85 blazer. It has the fuel gauge next to the speedo, the one I have has the smaller fuel gauge on the lower left and I have the Rpm next to the speedo. Would I just be able to swap this out with any modifications?
775stepside is offline   Reply With Quote
Old 04-13-2014, 09:32 AM   #2
bigd65
bigd65's Avatar
Re: Gauge cluster question
No, have to repin the plug in the rear, maybe use your printed cercuit on the back of your cluster.
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 04-13-2014, 10:53 PM   #3
775stepside
Ah dang ok
Old 04-14-2014, 03:45 PM   #4
Ski-me
Ski-me's Avatar
It's definitely do-able but it takes some time and effort. Get both of them off and lay them side by side. Then you need to trace path on the printed circut board and compare the two. Then re-pin.
why are you swapping? They usually go the other way around (try to swap in tach for big fuel gauge).
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 04-14-2014, 03:55 PM   #5
hatzie
Moderator
hatzie's Avatar
What's wrong with your tach cluster?
Instrument cluster plug terminals for 73-87 in the FAQ.
http://67-72chevytrucks.com/vboard/s...d.php?t=456877
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-14-2014, 05:43 PM   #6
ray_mcavoy
I'd be curious to know as well. If it's a 78 or newer tach and it's reading too high the fix is fairly simple --> http://howtoalmanac.com/kevin/projec...chfixtruck.htm
ray_mcavoy is offline   Reply With Quote
Old 04-15-2014, 02:16 AM   #7
775stepside
We'll I had put aftermarket gauges, then took them out, so I'm missing my oil pressure and coolant temp. My tach doesn't read anything. It only spikes up once when I put the key in. I picked up this other cluster for $10. The truck is 2hours away at my parents house and I plan on driving it to my house and I just wanted to install that cluster with all the gauges just for the trip
Old 04-16-2014, 10:40 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
i did a swap in my 78 below but it was idiots to gauges,and yes wires need to move
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
