Old 04-13-2014, 10:00 AM   #1
BLT gmc
New metal 4x4 upper radiator pipe pics
This is a project I have been working on for my 69 GMC K10. Several people have asked for pictures. These pictures are of a modified pipe, based on the OEM pipe. I modified it to fit better. Its made out of 304 Stainless steel with mandrel bends and hose beads. I am not a vendor, but I have had requests to make these pipes. Is there any interest? I can make them out of aluminized steel.
BLT gmc is offline   Reply With Quote
Old 04-13-2014, 10:16 AM   #2
74baggedbug
Re: New metal 4x4 upper radiator pipe pics
I'll take 1!
74baggedbug is offline   Reply With Quote
Old 04-13-2014, 10:17 AM   #3
BKSS67
I'd be interested
Any idea on the cost for the SS version and the alumni used steel version?
What is modified on your version? Can you make one that exactly matches the original one instead of a modified version?
BKSS67 is offline   Reply With Quote
Old 04-13-2014, 10:54 AM   #4
jmader
jmader's Avatar
Are these used on all years of out trucks 4x4?
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 04-13-2014, 11:20 AM   #5
sboris
sboris's Avatar
Those look great. I'm still interested depending what they will cost.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 04-13-2014, 01:09 PM   #6
530FF
Interested pending cost
530FF is offline   Reply With Quote
Old 04-13-2014, 04:53 PM   #7
BLT gmc
74baggedbug- Keep me in mind, I actually have not built any other than the one I needed. After I had a lot of people asking to see the mandrel bends and the hose beads, I thought about helping others out if there is enough interest.
BKSS67- The SS is about 60-70 % more expensive. The pipe costs more, it is harder to bend-bead-weld, harder on the equipment. The modifications I made are- I increased the distance between the two bends closest to the engine by 1.5 inches, I shortened the longest straight part by ~1 inch, and finally the end connected to the thermostat housing is more parallel to the pipe itself, less rotated I guess. Yes, I can make one identical to the original- I am in the process of securing a know original pipe to copy.
jmader- I think these are 69-72 p/u and blazer, but I am not an expert.
sboris/ 530FF- Aluminized pipe if I decide to make them may be $100-125 shipped. ? too much ? I have to start with two pipes because the mandrel bender clamps will only work on one pipe if the bends are >4 inches apart. 3 mandrel bends. 2 hose beads. Pipes have to be trimmed a the ends- resulting in some waste- again because the clamps have to have a minimum length of pipe to grab. And finally jigged up and TIG welded. Feed back is appreciated Thank you, Bruce
Old 04-13-2014, 04:57 PM   #8
74baggedbug
Still Intrested but I'll take some measurements again on my motor being I have a serpatine setup and make sure it will clear the alternator ..
Old 04-14-2014, 07:56 PM   #9
sboris
sboris's Avatar
I completely understand what all goes into these. They look top notch. I had in my head I was willing to go around $75. So, I'm out for now. Probably worth that for what goes in them, but just where I'm at.. Thanks for posting and offering these up though.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 09-22-2014, 06:31 PM   #10
gmc 2500 4x4
might need one
gmc 2500 4x4 is offline   Reply With Quote
Old 09-22-2014, 09:12 PM   #11
BLT gmc
PM sent. Bruce
Old 09-23-2014, 12:32 AM   #12
BKSS67
Bruce
I was one of the guys originally interested in one of these. I have since purchased an original one. However, I am still interested in one of yours. What are your prices for an aluminized and SS one? I would prefer an exact copy of the original tube.
Brian
Old 09-23-2014, 07:06 AM   #13
BLT gmc
PM to BKSS67.
Old 05-08-2018, 07:00 AM   #14
dirish
dirish's Avatar
Any chance you have one of these for sale?
Thanks Dan
dirish is offline   Reply With Quote
Old 10-29-2018, 09:40 PM   #15
botmfedr1
botmfedr1's Avatar
Do you still have any of these for sale?
botmfedr1 is offline   Reply With Quote
Old 10-29-2018, 09:49 PM   #16
jeffahart
jeffahart's Avatar
I'll take one if you feel like doing a batch! I have making one on my to do list for a couple years now!
j
White K20
jeffahart is offline   Reply With Quote
Old 10-29-2018, 10:19 PM   #17
72swbcamo
Active Member
BLT nice job. Am I to assume that this is a two piece tube welded on the long straight?
Can hardly see the weld. I work for a company that manufacture similar tube for the aerospace industry. I was thinking about asking someone in work to try to bend one. I don't think that going to happen. Good luck on a tube that will dress up any engine bay. I'll be watching to see you pricing.
72swbcamo is offline   Reply With Quote
Old 11-27-2018, 01:16 PM   #18
McDeezl
Interested if these are available for sale.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=626178
McDeezl is offline   Reply With Quote
Old 02-13-2022, 11:03 AM   #19
duallyjams
duallyjams's Avatar
That's the nicest one I've seen made.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-13-2022, 11:41 AM   #20
BigBird05
Does anyone know why GM use a pipe on the 4x4's and used just a hose on 2x4's
BigBird05 is offline   Reply With Quote
Old 02-15-2022, 10:07 AM   #21
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I purcahased two of these a few years ago from Bruce. Run them on my 4x4's. Quality work, nice material and fit was spot on. You want be disappointed in the product.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 02-15-2022, 12:40 PM   #22
jimijam00
Did you polish them up?
jimijam00 is offline   Reply With Quote
Old 02-15-2022, 12:52 PM   #23
Accelo
Accelo's Avatar
The motor was set back further in the chassis. This made for more distance between the motor and the radiator. Now days manufactures seem to have no issues using longer rubber hoses without the metal piping.
Accelo is offline   Reply With Quote
Old 04-15-2022, 09:41 PM   #24
kilokoa
If you are still making these, I would be interested in one.
kilokoa is offline   Reply With Quote
Old 08-17-2023, 04:04 PM   #25
nicklear36
nicklear36's Avatar
Interested in aluminum
nicklear36 is offline   Reply With Quote
