Old 04-11-2014, 02:04 PM   #126
original-71
///Relaxed Atmosphere
original-71's Avatar
Re: '72 Drop member... "Betty"
very nice engine
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 04-12-2014, 02:06 PM   #127
GoaterAz
GoaterAz's Avatar
Originally Posted by olrosa View Post
Now that's more better. Lol
Those valve covers looks incredible, great job!
I'm still learning about all this, but I see on PML's website they will drill the the PCV and breather for you. I'm assuming the passenger side rear is the PCV and the front of the driver side cover has the breather, can you just fill the engine with oil by unplugging the breather?
(I believe) My current breather is routed from the valve cover to the air cleaner, with yours it just looks like a plug with no hose, are you going to route a hose to the air cleaner or is that plug sufficient?
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline   Reply With Quote
Old 04-12-2014, 03:14 PM   #128
olrosa
olrosa's Avatar
You got it! Just pull out the breather and fill there. They give you a little bent tube to use. I am not running anything to the aircleaner
olrosa is offline   Reply With Quote
Old 04-13-2014, 10:00 AM   #129
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
With a drop member is the ride height adjustable? (silly question really, I know it is) I mean, I know it wont go back up to stock height....but is the idea that it's always pretty much draggin frame? I only ask because I want to go this route, in fact, I just had my estimate from the guys at PB come through the other day. But I use my truck daily and for haulin now and again.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 04-13-2014, 01:16 PM   #130
olrosa
olrosa's Avatar
You would be fine if you use accuair with it. They have sensors to keep whatever ride height you want, even if your hauling a load. Depending how low you want to go you could get a PB setup without changing the front crossmember. I think it's the stage 1 setup, can't remember
Old 04-13-2014, 05:18 PM   #131
eightbanger
454 MAKES IT ROAR
Thanks Seth, I'm way new at this but keen to go the PB route with my truck‎...are there any other major modifications you need to make in order to install PB drop member? I read on superflysteiny that he shortened the rear end, is that necessary? And does the drive shaft need to be modified?‏
Nigel.
No more pain.
Old 04-13-2014, 05:23 PM   #132
olrosa
olrosa's Avatar
Pretty much need to strip truck to bare frame., that's really the easiest. Not nessecarry to narrow the rear end. Yes drive shaft will probably have to be modified. You should run a 2 piece if you want to lay frame. Go with porterbuilt from the start. I have built some stuff and tried cheaper routes and it's not worth it. PB is the best and worth every penny!
Old 04-13-2014, 05:33 PM   #133
eightbanger
454 MAKES IT ROAR
Thanks mate.
Nigel.
No more pain.
Old 04-14-2014, 11:28 AM   #134
GoaterAz
GoaterAz's Avatar
I went to bed thinking about how clean that engine looks, lol. Literally, seeing that front runner and valve cover set up is going to cost me a bunch of money, lol. I had a couple questions when you have a minute.
Are there any performance/ventilation issues with having the PCV mounted inboard on the valve cover? Most I've seen are on top.
Was there a particular reason you had yours drilled for the PCV on the rear passenger and the breather on the front driver side cover? My current setup has the PCV on the rear driver and breather on the front passenger, just trying to pick your brain a little...I appreciate the help.
Me neither.
Old 04-14-2014, 12:33 PM   #135
olrosa
olrosa's Avatar
The front runner system is a little pricey, but sure does make life easy. I had to get it because I'm running double hump heads and do not have and holes drilled in the heads for mounting anything. Front runner system mounts off the water pump. And it comes with water pump alternator a/c compressor... everything
No issues with ventilation. PML drills it there to look cleaner and they have a baffle built in there between where your rocker arms are
Old 04-15-2014, 04:16 PM   #136
eightbanger
454 MAKES IT ROAR
Anymore progress?
Nigel.
No more pain.
Old 04-15-2014, 11:10 PM   #137
olrosa
olrosa's Avatar
Hey give me a break. Hahaha. Jk. Worked on the cab quite a bit today getting everything put back in. I will post pictures soon. Trying to get cab on chassis next week
Old 04-16-2014, 01:02 AM   #138
superflysteiny
superflysteiny's Avatar
rear ends do have to be narrowed if you have a wide rear end and you run a full width offset on the rear 10 inch wheel
superflysteiny is offline   Reply With Quote
Old 04-16-2014, 09:31 AM   #139
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Have you put a high hump in the cab yet?
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 04-16-2014, 10:30 AM   #140
olrosa
olrosa's Avatar
Didn't know I had to with 700r4? Doh. do I?
Old 04-16-2014, 11:08 AM   #141
mcbassin
Still Learning
mcbassin's Avatar
Your engine looks great!
Old 04-16-2014, 11:10 AM   #142
lolife99
67-72 parts collector,…
lolife99's Avatar
do I?
Yes.
The Extreme Dropmember requires a factory high hump.
It's easy to add.
Keith
Convert to disc brakes.
Old 04-16-2014, 11:23 AM   #143
olrosa
olrosa's Avatar
Yes.
It's easy to add.
SON OF A.... I ordered wrong carpet then.
Old 04-16-2014, 11:29 AM   #144
olrosa
olrosa's Avatar
Soooo, who's got a high hump I can buy? lol
Thanks for the heads up Lowlife
Old 04-16-2014, 11:36 AM   #145
lolife99
lolife99's Avatar
They are on the parts board from time to time.
The versions with a 4-speed shifter hole or a transfer case shifter (or both) are the cheapest.
But thanks to the Dropmember's need for them,... they are getting harder to buy on this board.
Keith
Old 04-16-2014, 01:49 PM   #146
eightbanger
454 MAKES IT ROAR
This guy had two for sale, looks like he's sold one.....http://67-72chevytrucks.com/vboard/s....php?p=6587551
Nigel.
No more pain.
Old 04-16-2014, 06:14 PM   #147
olrosa
olrosa's Avatar
Found one, thanks guys!
Old 04-16-2014, 08:12 PM   #148
olrosa
olrosa's Avatar
Cab progress. (Before high hump) Lmfao
Old 04-16-2014, 11:56 PM   #149
olrosa
olrosa's Avatar
High hump!
Old 04-17-2014, 07:20 PM   #150
olrosa
olrosa's Avatar
Here is how we're running the plug wires to hide them. Also my buddy ceramic coated the exhaust manifolds
