Old 04-13-2014, 04:27 PM   #1
str8edgec10
Deleting passenger side fuel tank
I've searched a bit and can't find out what to do with all the old wiring on the passenger side. Not really concerned about the fuel selector switch in the dash. I only have two wires hooked up to the driver side tank. If I just ground the ground from the passenger tank would that work. Fuel gauge is not reading.
str8edgec10 is offline   Reply With Quote
Old 04-13-2014, 05:33 PM   #2
ray_mcavoy
Re: Deleting passenger side fuel tank
Trucks with dual tanks have a "dual tank wiring harness" that plugs into the "base equipment" fuel sending unit wire.
So to convert back to a single tank, all you have to do is unplug the base equipment sending unit wire from the dual tank harness and connect it directly to the sending unit (it should already have the necessary plug). The connector you have to unplug (and move to the sending unit) should be located along the frame somewhere near the tank switching solenoid valve.
All of the dual tank specific wiring harness can either be left in place (unused) or removed as desired.
Finally, if the fuel gauge still doesn't work after plugging the "base equipment" sending unit wire directly onto the sending unit, you'll have to do some additional troubleshooting to see if there is a bad connection somewhere or a faulty sending unit or gauge.
ray_mcavoy is offline   Reply With Quote
Old 04-13-2014, 07:36 PM   #3
str8edgec10
Thanks Ray Mcavoy. I will try that.
