Th350 shifting early
The turbo 350 in my 70 is shifting way to early. It makes the 1-2 shift around 3,300 rpm and the 2-3 shift happens 3,900 and I was just wondering what ya'll thought it would be? Thanks in advance!!
1970 SWB "old flame" 1967 SWB c10 sold 1972 Elcamino 496 2012 Denali HD dmax |
Re: Th350 shifting early
Is the detent/kickdown cable hooked up?
I don't remember if the modulator was for shift points, or shift firmness, but some are adjustable. I thought the detent was for high rpm shift points, and the modulator controlled the low shift points/firmness in drive
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
You might go down south in the performance section and ask ,have you done anything to it or did it just start doing it.Could be the govenor,could be in the valve body , could be clutchs need a little bit more info.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
I bought the truck back about a year ago and it was doing it then. The kick cable is hooked up and working. The teams isn't slipping so I wouldn't think it was clutches. I can shift it manually and it will stay in that gear until I up shift..
x2 for the modulator. I'd check/replace it to start with.
project: "my happy mess" |
I did that yesterday after posting and it didn't make a difference...
Where the vacuum line goes in, there should be a screw head in the port. it's adjustable, so try some trial and error
![]() Join Date: May 2007
I would try adjusting the kick down cable. It is simple, free, and does change when it shifts.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
