Old 04-14-2014, 09:34 AM   #1
Houston Ben
Houston Ben's Avatar
Scangauge II and pending codes??
Hi all,
I am using a scangauge II for my RPM, MPH, Temp, Intake temp and for clearing codes. Well, when I check for codes it says "No codes found" or something to that effect, but it does have pending codes it will not clear
B2AAA
B2A00
P0007
B0800
When I look them up I can't find too much on them except for the P0007. Is anyone familiar with these? Should I get a real scanner and see if I can clear?
Thanks!
Ben
Houston Ben is offline   Reply With Quote
Old 04-14-2014, 10:16 AM   #2
littlevictories
Re: Scangauge II and pending codes??
i had a couple of those weird BXXXX series codes pop up when I first did my swap. I cleared em and they havent come back since.
i was told they are related to "body sensors" or something and not to worry about them.
littlevictories is offline   Reply With Quote
Old 04-14-2014, 10:39 AM   #3
ls1nova71
ls1nova71's Avatar
Codes that start with B are body control module codes, P are powertrain and C are chassis. I would clear them and see if they come back.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-14-2014, 12:08 PM   #4
Houston Ben
Cool, thanks for the replies, I will be barrowing a obdII scanner Wednesday to clear them!
Old 04-14-2014, 02:17 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Pending errors aren't real errors, the engine needs to see the same failure a few times before calling them "Active". It usually takes 3-trips (warmup, drive, off) to cycle and clear them, or confirm them.
This is a known thing with the self-powered gauges like the Scangauge. Check the wiring for your diag port, and make sure they scangauge is securely plugged in at both ends. The obdII end can wiggle free, some people like to zip tie it in place.
Its the gauge trying to "read" codes that aren't there. The AAA code and the 800 code are pretty common. Turn everything off, check the connections, try it all again. The codes should either disappear on their own, or allow you to clear them.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-14-2014, 09:45 PM   #6
Houston Ben
Thanks BR3W!
