Old 04-16-2014, 01:23 AM   #1
davidhelgesen
72 gmc 2500 info?
Hi guys as the title states I'm looking for info about the 72 gmc 2500. One has come up for sale in my area and I'm thinking about picking it up.
What I want to turn it into is an autocrosser that I can drive on the street as well.
So my main questions are: the 2500 is 3/4 ton right? Also what are the differences between 1/2 ton and 3/4 frames? Would bolting a high end crossmember onto a 3/4 ton frame be any different? Also did the 2500's come with leaf springs or coils?
Its also a camper special if that helps.
Thanks for any help
davidhelgesen is offline   Reply With Quote
Old 04-16-2014, 01:49 AM   #2
SS Tim
SS Tim's Avatar
Re: 72 gmc 2500 info?
Yes it is a 3/4 ton and probably has leaf springs a maybe even helpers as well.
The 3/4 ton frame is heavier than a 1/2 ton by about 25%
By "high end crossmember" you are speaking about a drop notch kit, it should be very workable. Others will have to help you on that.
However I do guestion trying to use a probably 4500lb truck as a base for an autocross. It doesn't sound much better than a Austin Mini pickup for hauling cement.
While anything can be done including a complete replacement chassis there are probably better choices. I'd recommend doing more research.
If it matters to you these are the Chevy frame numbers which I believe are the same.
C Blazer
C10 115"
C10 127" 6.04" height 2.53" flange width 0.156" thick 2.98 section modulus
C20 127" 6.11" height 2.46" flange width 0.194" thick 3.71 section modulus
SS Tim is offline   Reply With Quote
Old 04-16-2014, 01:55 AM   #3
davidhelgesen
I would be cutting it down to a short wheel base
Old 04-16-2014, 02:05 AM   #4
SS Tim
SS Tim's Avatar
Well that is a start, extrapolating a bit that is probably about 130lb. :-)
A stripper manual everything, but including disc brakes and a V8, 1/2 ton swb curbs at about 3700lb.
Old 04-16-2014, 02:08 AM   #5
davidhelgesen
Haha maybe not autocrossing but maybe take it around a road course. I want to go with a No Limit Wideride kit
Old 04-16-2014, 02:53 AM   #6
SS Tim
SS Tim's Avatar
My choices would be a little more dedicated. If you haven't been, get to a VARA Big Bore Bash it will remind you what big blocks were intended for. http://www.vararacing.com/#!big-bore-bash/cr0
Or you could buy my Camaro SS then I can buy a 69 GMC that caught my eye. :-)
Old 04-16-2014, 03:57 AM   #7
davidhelgesen
Hahaha at least my potential truck would beat that rig in an autocross event
