04-16-2014, 10:45 AM | #1 |
Rear coil spring ?
on the rear coil springs spring mounting clamps one is threaded and one isn't I
which one is the top clam |
04-16-2014, 11:09 AM | #2 |
Re: Rear coil spring ?
if i remember right with out going to look on my truck , i think its the bottom one.
the bolt comes up from the bottom to screw into the threads..the top just goes thru the frame hole..
04-16-2014, 03:36 PM | #3 |
Never Ending Projects
This is correct.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
04-16-2014, 03:40 PM | #4 |
Yup, bottom is threaded.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
