Old 03-26-2014, 09:48 PM   #151
ridinlow68
ridinlow68's Avatar
Re: 68 C10 Project FROSTBYTE Extreme Dropmember
UPDATE! Look what came in while I was on vacation! I was actually excited to get back to open it up! haha After doing some thinking about where I wanted to go with this project, I decided I wanted to go with a 4L80E instead of a 700R4. It'll be a stronger transmission, and I'll have more control over it. It has a 2200 stall converter, which will be plenty for me.
I'm still deciding on which transmission controller I'm going to be going with, I've looked at just about all of them, any opinions on them would be greatly appreciated! I'd like to get one that is compatible with an IPAD because I'm going to be controlling everything else on the IPAD.
No pictures of progress of the rest of the truck, just been cleaning up the cab a little bit seeing how much rust I'm dealing with. It's the typical places for rust, small pinholes in the cab corners and a little bit at the rockers near the kick panel. The drip rails don't look bad either. We'll see how bad everything really is once it's completely stripped down.
Rick
1968 Chevy C10 Shortbed, 383 w/4L80E, Extreme Dropmember, Accuair I-Level, Bonspeed Big Blocks
ridinlow68 is offline   Reply With Quote
Old 04-13-2014, 10:28 PM   #152
ridinlow68
ridinlow68's Avatar
No updates, just a couple pictures. Pulled it outside to get some sun! This is at ride height. Of course I couldn't resist to throw the front fender on there real quick. Can't wait to get moving on this, works' been keeping me real busy lately...
Rick
Old 04-13-2014, 10:41 PM   #153
Bennett68C10
Bennett68C10's Avatar
Looks great, did you get that big ole 4l80e installed yet. Just wondering if you have to modify the floor any to get it to fit. I really want one for my truck eventually.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-13-2014, 10:46 PM   #154
mooseknuckles
mooseknuckles's Avatar
nice!
mooseknuckles is offline   Reply With Quote
Old 04-14-2014, 10:35 PM   #155
ridinlow68
ridinlow68's Avatar
Thanks! I haven't installed the 4l80E yet...I'm wondering the same thing! lol I did get a high hump to get me part way there, but I'm thinking I'm going to have to extend it back and up a little bit more. I'll make sure to let you know when I've got it installed and the floor modified.
Rick
Old 04-14-2014, 10:36 PM   #156
ridinlow68
ridinlow68's Avatar
Originally Posted by mooseknuckles View Post
nice!
Thanks!
Rick
Old 04-15-2014, 12:34 AM   #157
rwade
rwade's Avatar
I've got the mild drop member with the 4L80E and I've got a ton of room. I know the extreme is an additional 2" but I'd test fit before just cutting your floor. I did cut the big "ears" off the bell housing for header clearance though. Love the direction your truck is taking. Very nice!
Wade
rwade is offline   Reply With Quote
Old 04-16-2014, 10:12 PM   #158
ridinlow68
ridinlow68's Avatar
Wade
Thanks for the heads up! I got the high hump trans tunnel, so I'm going to start from there and then see what, if anything else needs to be cut. I'll be sure to take pictures.
Rick
Old 05-07-2014, 05:41 PM   #159
bcutt
bcutt's Avatar
Truck looks awesome man! I am staring at my bare frame right now and it is just begging for some Porterbuilt/Accuair love..LOL
Brandon
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see."
- Thomas Jefferson
72 C10 SWB "Work in Progress"
bcutt is offline   Reply With Quote
Old 05-08-2014, 10:23 PM   #160
ridinlow68
ridinlow68's Avatar
Brandon
Thanks Brandon! Pretty much any frame looks a lot better with Porterbuilt/Accuair products! haha
Rick
Old 05-08-2014, 10:34 PM   #161
Mattyparty
Awesome
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=602142
Mattyparty is offline   Reply With Quote
Old 05-11-2014, 09:27 PM   #162
ridinlow68
ridinlow68's Avatar
Well I finally have a little bit of progress to report! My dad and I were able to get the transmission installed along with the high hump, which looks like it's going to fit perfectly! We also ended up cutting out the dash, I'm looking at getting a custom dash made up, so it had to go! No turning back now! The cab and doors are hopefully going to get media blasted this week and then it's off to the body shop! Can't wait!
Rick
Old 05-11-2014, 10:02 PM   #163
jtp67-72
jtp67-72's Avatar
Hey Rick I thought i had enough room too but when I started setting the 4-5* trans hit the high hump...Not tryin to spoil it but make sure the rear drop is right....May just have been me!!!...........Update ....just realized your using sbc instead of ls....may be the difference....my bad.............jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 05-11-2014, 10:17 PM   #164
ridinlow68
ridinlow68's Avatar
Hey Jim, thanks for the heads up, not sure how much of a difference the 2 blocks would have. Where it's at right now is about 6* and needs to shift up a little less than an inch to make it 5*. It's going to be tight, I had about an 1.25" clearance, so I may need to pound on the high hump to get a little more breathing room. I'm going to be back on it tomorrow night to get it squared away for sure.
Rick
Old 05-11-2014, 10:27 PM   #165
uxdesigner
Really nice build! Excellent wheel choice!
uxdesigner is offline   Reply With Quote
Old 05-11-2014, 10:34 PM   #166
jtp67-72
jtp67-72's Avatar
I had to take two high humps and make one about 2" taller....let me know if u have to raise ..i will post picks od mine...jim
Old 05-11-2014, 10:49 PM   #167
ridinlow68
ridinlow68's Avatar
Alright, sounds good, I'll let you know. Thanks a lot!
Rick
Old 05-12-2014, 06:35 PM   #168
SCOTI
SCOTI's Avatar
Ditto on the one I was putting together (68). It was a sbc Dropmember Extreme that I cut some sbc to LS adapter plates for.
With the sbc/700r4, no clearance issues w/the high-hump cover. Once the 6.0/4l80e was swapped in, there was definite interference. With some adjustable conversion plates, I might have been able to pull the motor farther forward but I was worried about clearance farther up front between the radiator/fan & accessory drive.
I had to trim extra sheet metal when setting it up for 3-5° drivetrain angle. It also might be compensated for w/the correct DM LS style mounts....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-12-2014, 10:12 PM   #169
ridinlow68
ridinlow68's Avatar
So I just got back from the garage after re-adjusting everything and I now have the transmission set to 5*. I'm just hitting in a couple spots, but it looks like all I'm going to have to do is change the shape of the top of the high hump by pounding it up and giving it a curve instead of it being flat. If I went up to a 3* slope I could definitely see that there would be more interference and it would become an issue.
When you guys were measuring the 5* slope of the transmission, where were you taking it from? The back of the tail shaft? Maybe I'm taking the measurement at the wrong spot... Everything seems to look right and after checking my other angles for the drive shaft, those seem to be pretty much spot on as well... Let me know if you could. Thanks!
Rick
Old 05-12-2014, 10:25 PM   #170
lolife99
67-72 parts collector,…
lolife99's Avatar
Back of the trans with the frame level.
Not setting on its wheels.
Keith
Convert to disc brakes.
Old 05-12-2014, 10:32 PM   #171
jtp67-72
jtp67-72's Avatar
I like to use the bellhousing flange ( back of block ) or if intake is off lay straight edge across end valleys with digital angle finder I have...remember on most sbc intakes u can't use carb flange because it already has 3-4* built in to level carb when engine and trans are set to specs....I have used back of tailshaft too..........jim
Old 05-12-2014, 10:35 PM   #172
ridinlow68
ridinlow68's Avatar
Thanks Keith! That's where everything was at, so it looks like I'm in good shape.
Rick
Old 05-12-2014, 10:38 PM   #173
ridinlow68
ridinlow68's Avatar
Alright, cool, I'll check both those places too. I wish I had a digital angle finder, it would make things a whole lot easier. Should probably just go ahead and get one since I'll be using it quite a bit more. Thanks Jim.
Rick
Old 05-12-2014, 10:47 PM   #174
jtp67-72
jtp67-72's Avatar
Sears is where i got mine.....and I forgot .....Keith is right....frame level............
Old 05-18-2014, 08:52 PM   #175
Chvy2NV
Hey guys. You can download an app by Tremec. It's free and works really well. If something is off. It also tells you what you need to do to get it within the acceptable parameters.
Chvy2NV is offline   Reply With Quote
accuair, cpp, dropmember, mmw, porterbuilt
