Re: Best Drop For my Budget?
for that much coin your looking at drop spindles and heated/cut springs in front, and heated/cut springs in back with lowering blox. Get it all at Ebay,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
![]() Join Date: Mar 2013
Heck...get some 3/2 drop springs an you'll be good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
To cut a coil is OK, to heat a coil bad. Rear coils can't be cut because of coil cups. There are those who run this but how safe is a coil not bolted in? I say Ride Tech rear bags with schrader valves for adjustment and 2" coil front. Save up for brakes and drop spindles.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#4 | |
Maybe what you mean is drop springs are Better then cut springs.
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
What I mean is the rear being cut leaves the coil unable to bolt back to trailing arms. So if you hit a bump or encounter a situation where the rear shifts this would be unsafe. Right is right and cheap is not always safe. I have seen bad judgment go wrong. Heating springs bad idea. I have run cut coils on the front but does stiffens ride.
#6 | |
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
