Old 04-14-2014, 10:58 PM   #1
Jbm1956
56 chevy pickup shocks
Im working on my 56 chevy pickup right now. And ive received a lot of advice from Dubie and I appreciate your help. Im running a 3" dropped axle and sagged leaf springs which gives me around an additional 4" drop. I will eventually run posies or monos leqfs in the front. My question is what shocks do you guys recommend using for what I have. Thanks again
Jbm1956 is offline   Reply With Quote
Old 04-15-2014, 11:32 AM   #2
mr48chev
mr48chev's Avatar
Re: 56 chevy pickup shocks
The axle won't make any difference as the bottom of the axle is still in the same spot in relation to the frame as it was with the stock axle. the sagging springs might require a slightly shorter shock to keep from bottoming out and as you are thinking about swapping springs I'd say go with shocks that work with the mono leafs.
Most of us use the Monroe shock length/mount sheet to figure out what length of shock with proper ends we need and then either go with the Monroe number of choice or use that Monroe number and cross it to our favorite shock brand. Most shock brands have cross reference charts in the catalogs where you can cross the number over.
Ride wise it's your butt and back that is riding on them and that may or may not match that the rest of us like. I like a medium range gas shock that isn't too stiff or too soft while others want perfomance shocks or stiffer or softer shocks.
My ongoing truck projects:
Old 04-15-2014, 11:39 AM   #3
Jbm1956
Whats the best way to determine what length of shock I would need
Old 04-15-2014, 08:17 PM   #4
_Ogre
_Ogre's Avatar
monroe length specs
truk is on stock springs with a flipped axle and uses monroe-matic 33086 with the stock mounts top and bottom
i have since converted to air shock. i searched what the shock fit and the cross referenced it air shocks
look at the link and the number i posted, will probably fit
shop air compressor timer
Old 04-16-2014, 01:48 AM   #5
Jbm1956
I think im good for the rear. The front shocks are my issue
Old 04-17-2014, 02:16 PM   #6
Jbm1956
Anyone have part numbers for the nitro slammers that you use for your lowered straight axle with monos/posies/or sagging springs. Thanks
Old 04-17-2014, 05:34 PM   #7
made2drag
made2drag's Avatar
Originally Posted by _Ogre View Post
monroe length specs
and you did weld the axle saddles right?????
made2drag is offline   Reply With Quote
Old 04-17-2014, 05:42 PM   #8
_Ogre
_Ogre's Avatar
maybe. is it important???
