oil PSI line
I have my 72 in the shop at work here and I am trying to figure out where the oil psi line goes. It screwed into the block on the inline 6 but where does it go on this 350? the engine is from and 82
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Resident Curmudgeon
![]() Join Date: Dec 1999
Behind the distibuter on all small blocks I've seen.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Ok, here is the problem
This is the oil psi line from the inline
and it's supposed to hook up to this??
looking at the block just in back of the intake manifold on the drivers side is where that oil line will screw into the block
pic
ok so all i have to do is unscrew the one in this pic and screw the factory line in.
MAny thanks
Resident Curmudgeon
Good pic, that's it. If I were you I'd go to NAPA and get a replacement line for the V8. The I6 line is too long and may break or get kinked in your effort to route it.
Pennyless Fool
Remove the pressure sending unit thing there behind the dist and put your line fitting in its place.
Beat me to it ![]()
"Who owns this car with the peace sign, the mag wheels, and four on the floor?" 67 Short Step 283/TH400/4.11 |
#10 | |
#11 | |
Resident Curmudgeon
this is the one that threads into your gauge in the dash bezel right?
Resident Curmudgeon
It's been a while since I had that trucck with the replacement line, but I believe it ran directly from the block to the sending unit on the dash. The stock configuration used 2 separate steel lines coupled together outside the firewall. The stock line that attached to the block was coiled like a slinky to help with the vibration cracking problem, the other stock line it was coupled too was straight thru the firewall to the pressure gauge.
you could also probably get one free or dirt cheap from a V8 truck at a junkyard...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
#15 | |
Resident Curmudgeon
Not freezing your a$$ off in Flin Flon Canada in January - priceless. ![]()
#16 |
hahah yeah it's gonna be -42F for the next 2 days
#17 |
Merciless Butcher
Go to the NAPA counter and ask the partsman for a 1/8" breakaway ferrule and some 1/8" copper tubing. Thought I would share a pic with you. This is my oil pressure line on top with the vacuum gauge line on the bottom. I used 4-AN line and bulkhead fittings.
Your Bought And Sold....I Got Your Soul! |
#18 |
BOWTIE FOREVER
Hey dubie when ya pull that line off for your oil pressure I'm interested in the fitting that goes into the block that the round cylinder screws in.You wanna sell that?
69 C-10 SHORT FLEET BED 350 4-BOLT/400 turbo upper & lower molding 65 IMPALA 2-DR 283/POWERGLIDE 66 IMPALA 2-DR hopefully 283/350 ~ CAMELTOE ROCKS ~ |
#19 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Gonebad, I'd like to see more pictures of your truck please.
Not just the braided hoses, the whole engine and everything.
