Old 04-15-2014, 06:59 PM   #1
stepside68longbed
unknown knock
I have a 68 307 with an auto 350 trans. there's a knocking noise coming from the front near all the pulleys.. I have the main drive pulley, fan, and alt. I've checked the fan it doesn't wobble and isn't loose, I checked my temp with a thermometer registered just over 150 so I figure the water pump is fine. the main drive pulley looks like it wobbles n so does the fan its hard to tell which one it really is with it all tied together.. I already took the plug wire out one by one and it still knocked it sounds like its from the front...
any suggestion? or troubleshooting?
stepside68longbed is offline   Reply With Quote
Old 04-15-2014, 07:09 PM   #2
hamjet
hamjet's Avatar
Re: unknown knock
You could remove the fan belt and start it to see if it still knocks.....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 04-17-2014, 08:25 PM   #3
stepside68longbed
Re: unknown knock
bent rod it locked up today
Old 04-17-2014, 08:40 PM   #4
imjeff
imjeff's Avatar
Re: unknown knock
Nobody wanted to say rod bearing, but it always lurks...good luck with your motor adventure! Build thread?
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 04-17-2014, 09:41 PM   #5
stepside68longbed
Re: unknown knock
im preparing to move to GA but after we move its full sped ahead in juneish ill have a 350 ready to burn some rubber :>
