Old 04-16-2014, 06:15 PM   #1
dixiepc
1979 6.2 k5
I'm getting ready to put a 6.2 in a 1979 K5 that I just bought. The radiator for the 6.2 is bigger like one for a 454. The 82' and up radiator supports have provisions for the shorter radiator or the longer one. But this 79' radiator support doesn't have these provisions. Did they ever have the longer radiators in 79' trucks?
dixiepc is offline   Reply With Quote
Old 04-16-2014, 06:39 PM   #2
V30 mongo
Re: 1979 6.2 k5
Quite a few changes were done for the 81/82 model years. The cab floor pan was changed, the dash, and the complete front end. The radiator for the diesel is big, really big. The newer front radiator mount should have the mounting holes. I guess you can install a diesel in the older truck, but it will take as lot of work. There is more than just the cooling system. Diesels require two batteries, the starter is also big, along with the wires. The fuel system must have a return system or you will have air in the fuel problems..
1988 V30/6.2/Sm465/NP205/5x6 4.56 axle/12,000 lb.GVW/Ramsey L600 front winch,Chelsea 321PTO on trans/ Ramsey L800 rear winch,Chelsea 352PTO on transfer/ custom steel flat bed with rear rollers.
V30 mongo is offline   Reply With Quote
Old 04-16-2014, 08:49 PM   #3
dixiepc
Re: 1979 6.2 k5
It won't be a big job at all. The return lines are already there. The engine with bolt right in. And the batteries are no problem.
I don't really think that the cooling will be a problem as they put these in Toyota Land Cruisers and you can't put a very big radiator in those. I just wondered what they did in 79' when they used a big block.
Old 04-17-2014, 12:45 PM   #4
crashz
crashz's Avatar
Re: 1979 6.2 k5
Both of my 83's and my 87 have the same 6.2 radiators, which are big in outer dimensions, but I think they are either 2 or 3 core radiators.
I've heard of people using a smaller, 4 or 5 core radiator in place, and actually improving cooling. Totally internet hearsay though and I have no proof of that working.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 04-19-2014, 09:03 AM   #5
Edahall
Re: 1979 6.2 k5
The large size radiator is needed for towing. These engines put out a LOT of heat when towing heavy loads.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 04-19-2014, 11:31 AM   #6
Corts60
Just here to tinker
Corts60's Avatar
Re: 1979 6.2 k5
To answer your question, yes, but only if it was a diesel truck. My '78 factory diesel has a bigger radiator than even the 454 powered trucks. There is a tranny cooler on the driver side tank, and an oil cooler on the passenger side tank. Of course the chances of you finding a factory diesel truck core support is going to be very hard. But, all in all, it can be done. If you need, I can take a picture for you.
Old 04-19-2014, 12:48 PM   #7
dixiepc
Re: 1979 6.2 k5
A picture would be great.
Old 04-19-2014, 03:01 PM   #8
Corts60
Just here to tinker
Corts60's Avatar
Re: 1979 6.2 k5
Hope these help ya buddy:
Old 04-19-2014, 03:20 PM   #9
dixiepc
Re: 1979 6.2 k5
Thanks for the pictures. It's hard to tell from the pictures but is that radiator core 34"?
I've wanted a truck with a 5.7 Diesel for a long but I'm afraid that parts might be too hard to find. They get some great mileage.
Old 04-19-2014, 04:07 PM   #10
ray_mcavoy
Re: 1979 6.2 k5
Interesting ... with the exception of the oil cooler & heater hose return, that doesn't look a whole lot different than the radiator in Dad's '77 with a 400 small block.
Did 400's use the same size radiator as diesels? I always thought they were the same as 454 radiators ???
For reference, this radiator has a 28-1/4" wide x 19" tall core. I know the 80's 6.2L diesel radiators are even wider than this.
ray_mcavoy is online now   Reply With Quote
Old 04-19-2014, 05:25 PM   #11
dixiepc
Re: 1979 6.2 k5
6.2's and 6.5's had radiators with 34" wide cores. Some were 17" tall and some were 19".
Old 04-19-2014, 05:52 PM   #12
Corts60
Just here to tinker
Corts60's Avatar
Re: 1979 6.2 k5
That does look pretty similar to the 400 radiator. Maybe they were the same. Yes, mine is a 34" core.
Old 04-19-2014, 11:59 PM   #13
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Re: 1979 6.2 k5
Aux battery trays for 73-80 are not a hard item to find, even LMC carries them, and they can be had used as well.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 04-20-2014, 12:18 AM   #14
dixiepc
Re: 1979 6.2 k5
Got no problem with that part. Just trying to figure out a longer radiator on a 79' core support. Or if the 28" radiator core will cool the 6.2.
I already run a couple of 6.2's so I'm very fimilar with them. Unless your towing or pulling a steep grade they actually seem to put out less heat than a gasser.
Old 04-20-2014, 06:32 AM   #15
Edahall
Re: 1979 6.2 k5
Yeah, you don't need much radiator to cool these engines if you're never intending to tow. They produce very little heat at idle compared to a gasser. However, they heat up fast towing huge loads and slogging up a hill.
Old 04-20-2014, 11:15 AM   #16
hatzie
Moderator
hatzie's Avatar
Re: 1979 6.2 k5
Radiators are usually measured to the ends of the core not the tanks.
I used a 4 row 29" x 19" core radiator in my '76. That's prolly 34" or 35" to the ends of the tanks. The problem you'll run into is the HD radiators were taller. I went from something like 16" 3 row to 19" 4 row. The top support is different depending on the core height.
I used a power steering cooler to keep the hydroboost happy.
I didn't get a radiator oil cooler. My oil cooler is an external B&M plate type unit similar to the one GM used on the T400 chassis diesels with modified hybrid cooler hoses (stock on the block married to AN braided from the cooler). Yes. I had to cut the core support to route the cooler hoses through.
The nasty part, for me, was fabbing mounts for the aftermarket parallel flow condenser and the oil coolers so it looked decent. It can be done without looking ghetto or blocking airflow.
I have an NV4500 so the tranny doesn't get a cooler.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-20-2014, 01:11 PM   #17
dixiepc
Re: 1979 6.2 k5
Man do you have a build thread on your 76'? I've got an 84' that I want to put a NV4500 in. Having trouble finding a pedal setup for hydraulic clutch with hydroboost.
