auto trans cooling lines ?
What are you using for the cooling lines? I tried alum tubing and have had problems with them. Thanks Rich
Re: auto trans cooling lines ?
I'm using http://www.speedwaymotors.com/Univer...-Kit,6769.html with a 700r4 and have had no problems.
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
The cooler circuit is pretty low pressure so you can safely use the flexible line like in that kit. Most auto parts stores will have inverted flare to push on hose fittings for the trans and 1/4 pipe to push on hose fittings for the cooler if you don't want or need the hard line in the kit....and they're cheaper. Just make sure to mount the flexible hose with brackets/U clamps in a couple of places so it stays put.
I've always just bought the correct diameter tubing in the lengths I needed from the parts house and bent my own up. It's a bit tedious to get it looking really great but it can be done and it is a lot easier to get it right if you do it with the nose off the truck if you did have the nose off the truck.
My cooler is brass so I used hard brazed 3/8 with barb fitting on the trans end, then short piece of rubber to barb on trans to allow for vibration and movement.
Thanks Guys I haven't decided witch way I will go. I thought the alum tubing would be a good way to go, easy to bend and flare. Twice I have had to retightened them. I just don't trust them. Rich
You can also go nuts and do braided stainless like I did to keep the theme of the underside.(crazy) I was at the frustration limit with the truck and how difficult things had been and I needed to use a remote cooler with a fan under the bed which would require many pretty precise bends. With Murphy at my side I wasn't up to it but I didn't really trust that much flexible hose. That's my story and I'm sticking to it.
