Sometimes the god's smile on us.
Just bought these drop spindles for $60.00 (Normally around $290.00)
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
Re: Sometimes the god's smile on us.
Some guys have all the luck!!! Good score
I believe they're 2.5" drop from Bellteck. Can anyone tell from the pics or know how to measure to make sure?
Should have a p/n & Bell Tech stamped on the backs. Google the p/n....
The only marking are "C 10 LH" and "C 10 RH" and a silhouette of a bell. These are on the front below the spindle. Any ideas?
Watch out for your cornhole !
![]() Join Date: Jun 2003
That logo tells you they were cast by the Bell Foundry in California. They cast spindle blanks for several companies.
I belive belltech only sells 3" drop spindles for the c10
Just found another sweet deal. 1980 2WD SWB frame. All the front & rear suspension including a 12 bolt rear axle.
Wait for it...... $200.00... DELIVERED!!!
